K
Kiesh
Hi folks, newbie here so thanks for reading! As above, my boiler is kettling and coming up with the good old Lf. code. I've disconnected the condensate trap from its pipe (which needs replacing as it's broken possibly cause of issue) but after removing the two trap bolts the trap is still solidly attached to the boiler. Any clues would be really appreciated!
You need to be gas safe registered to do what your doing hence you will not receive advice from this forum until you prove you are
the condense is part of the ***bustion cycle.
tou need someone to repair it as already mentioned.
thread closed.
cheers
