Nov 13, 2019
DIY or Homeowner
I have an ideal mini 24 boiler. It has started dripping water from the bottom of the boiler case after it has been on for a while. It also loses pressure slowly over 2 weeks. We have had an engineer and he said there is no sign of a leak inside the boiler so must be under floor which could be why pressure drops. Surely it shouldn't be dripping water or could it be condensation as very cold in kitchen where boiler is?
Any advice would be appreciated.
Definitely should not leaking from the casing if your engineer can't diagnose the fault them it time for a second opinion I would say . Kop
