View the thread, titled "Immersion heater is working but no hot water coming through taps" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
Please can someone help. Plumber came to property and said that the immersion heater is working. We do not have any hot water coming through the taps. He said that he is unable to locate a thermostatic mixing valve in the property which needs to be repaired. Where is this located?
Please find image attached of cylinder
[automerge]1565628047[/automerge]
Standard cylinder , you may have a TMV somewhere but you may have a shower or mixer tap ( passing ) can you try another plumber?
Isolate mains cold water and then see if you have hot come through.
My guess would be a mixer shower somewhere. What showers do you have? Also what taps?
Have you had a new bathroom installed recently? I would pop bath panels off and have a check in there for a tmv
does your have any flow of water if not is your float valve stuck in the supply tank with no water in the tank no flow of hot. alternatively if you have only cold water coming out of the hot tap then you have a problem with either a mixer tap passing or a tmv faulty (i have my doubts about this one as it would have probably needed checking a few times over the year)
Is that bottom immersion heater wired up? from the picture it does not appear to be.
Is the water from your hot tap the same temperature as the cold tap water, or is it a tad warmer but not hot, just tepid?
Reply to the thread, titled "Immersion heater is working but no hot water coming through taps" which is posted in Gaining Plumbing Experience on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Lai,
Darren Jackson,
