Where's the new mains stop tap going if you're removing this one?
Top question JCplumb,
I reckon Jon know's... (the OP)
It will be slightly further along from the plastic pipe. About 2 foot away between 15mm copper pipe. Will that be ok?
If that is your incoming mains you will still need a stop tap somewhere or are you putting it further up in the copper?Hi.
Have a mid 1980’s house with the mains water coming in from underground via a black plastic pipe, of which the external diameter is 27mm. There does not appear to be any markings on it, but maybe some faint green.
This goes into a 15mm copper pipe via a stop tap with compression connections. There is a slight leak and due to a new room layout I need to take apart and reconnect the black plastic pipe straight to 15mm copper pipe without the need for the tap.
Is there a straight connector out there for connecting this 27mm black plastic pipe straight to 15mm copper pipe please?
Thanks, Jon
Just with a philmac type fitting?You don't need an insert with black poly
They have always had insets when I have changed compression stop taps
I have ordered a selection of different sized inserts in plastic and metal just in case when I take it apart it looks like it requires one.
There might be one in the compression stop tap joint
