Incoming mains black plastic pipe to 15mm copper
View the thread, titled "Incoming mains black plastic pipe to 15mm copper" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi.
Have a mid 1980’s house with the mains water coming in from underground via a black plastic pipe, of which the external diameter is 27mm. There does not appear to be any markings on it, but maybe some faint green.
This goes into a 15mm copper pipe via a stop tap with compression connections. There is a slight leak and due to a new room layout I need to take apart and reconnect the black plastic pipe straight to 15mm copper pipe without the need for the tap.
Is there a straight connector out there for connecting this 27mm black plastic pipe straight to 15mm copper pipe please?
Thanks, Jon
Thank you, will look into philmac. Is this polly stuff brittle? Should I be being very careful with it? and how’s best to cut the end off for the best joint?
Ah yes I’m with you now! I guess until I take it apart I won’t know the diameter of the insert required? Although 22mm is most likely do you think?
Looking at Philmac now, but sooooo many fitting types I can’t work it out. The poly pipe is 27mm external diameter onto a 15mm copper pipe. Any idea which connector??
Hey Jon,
You know you've got to turn the water off at your boundary stopcock don't you.... otherwise you'll get a bit wet...😳😱.
Probably stating the obvious - no offence intended 😀
Hi Jim, already located and tested the boundary stopcock in anticipation for this job. But you were right to check with me as I’m A ‘newbie’ on here! and I can imagine it would be like being hit by a fire fighters hose!!!
Good for you Jon! I've got wet a few times as I reckon most plumbers have.... it's OK if it's summer time 🙂😀
Hi.
Thanks, Jon
If that is your incoming mains you will still need a stop tap somewhere or are you putting it further up in the copper?
I have ordered a selection of different sized inserts in plastic and metal just in case when I take it apart it looks like it requires one.
There might be one in the compression stop tap joint
I always use an insert in any plastic/poly pipe, especially if your going to tighten a compression fitting on to it. Black mdpe used to come in high and low density which determined the size of the insert.
Reply to the thread, titled "Incoming mains black plastic pipe to 15mm copper" which is posted in UK Plumbers Forums on Plumbers Forums.
Jon,
Tim S,
