Is .75mm Five Core Cable OK For CH Programmer?
View the thread, titled "Is .75mm Five Core Cable OK For CH Programmer?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I'm helping my brother who has recently bought a house. The plumbers who installed the wiring centre box and programmer for his vented back boiler system put them in a ridiculous place. It's on the side wall inside airing cupboard down the side of the cylinder. There is a few inches between the cyl and programmer.
He can neither see the screen or even know what time it says. Any use of programming it would need a contortionist with a head the size of a tennis ball. All he can do is press the hw or heating buttons to turn them on or off.
So, it has to be re-located. It has several short lengths of T&E connecting it to the the wiring centre, which is a few inches below the programmer. Can I use .75mm 5 core cable to link prog to wiring centre? Is it man enough?
Many thanks.
0.75 is good for up to 6A so it should be OK, seeing as boilers only need a 3A fused supply.
5 core is 3 phase/line colours plus neutral and earth. If its a y plan you'll have live and neutral to power the programmer, plus h/w on, h/w off and htg on, all live hence using the earth as a line conductor.
if its an s plan you'll only need the 4 so you can bin it off completely.
the earth CAN NOT​ be used for anything else other than a earth it is there to protect the cable
Only twin and earth, flex can be sleeved. I was under the same impression as you but NICEIC have said otherwise.
you won't get 0.75mm2 twin and earth so we can assume, in this case, the OP is referring to flex.
it can be used if there is no need to earth the item its wired to, ie double insulated. Many heating controls do not require an earth, you could argue that if a metal back box is used behind in the wall then you will want to earth this or if the cable is less than 50mm in depth inside a wall. which should also be protected by an rcd.
me I'd buy 6 core .75mm heat resistant flex for y plan, but he asked about 5 core originally, still like to use yellow and green for earthing myself and sleeve any others that are live, makes me feel more professional that way.
Apologies for causing some controversy. Yes, it's Y plan and it is flex I'm planning to use.
So, I'm now confused. Five core 0.75mm is sufficient to handle the load, but am I right in now thinking I can't use it because the earth would have to act as a phase wire? Do I understand it right that I'm not allowed to put tape on the earth to denote that it serves another purpose?
Perhaps it would just be easier to ask what wire/cables(s) the pros use to link a programmer to it's wiring centre.
you can use the earth as a line conductor, but if you need an earth then you will need an extra core. If you were using twin and earth type cable you can not use the earth as a line conductor due to size and/or lack of insualtion.
0.75 is fine if protected by a 3amp fuse.
If you can find it, and are happy to pay for it, then this would be the best solution. It's not readily available though so 5 core is often used as described.
Alternatively just use 2 x 4 core which will allow you 5 line conductors, 1 neutral and 2 c.p.c's if you need one (or even 2!)
You could use 2x3 core flex.
Most programmers are double insulated with a plastic back plate, so i would say it would be ok to tape the earth wire with red insulation tape. I would say that 85% of the systems I work on are like this.
If im doing a full re-wire from scratch i use 6 core, but i think you have to order it in at the merchants
Red tape? :6:
It's not a recognised line/live/phase colour now, brown grey or black. If you tape it red you should tape the neutral black as well.
your missing the point,the earth cable is there to protect the cable it does not matter if the clock or whatever is double insulated,it is against regs to use it as a control wire ,thats how fires start by not using a earth as its intended
its also how lame gets the occassional belt going into an airing cupboard in the dark to find out whats wrong 🙂
im sure someone who is looking at it knows what it means, otherwise they shouldnt be touching it
And now you know why plumbers shouldn't do electrics and vice versa! fortunately I employ both.
From an eleyricians point of view I am appalled at this thread, if this had been talking about doing something with a gas boiler croppie would have shut down pages ago.
Multi-core signalling cable is in stock at any good electrical wholesaler. Never use a single insulated (i.e. non in T&E) as anything other than as the cpc - if you don't know what that is , it's precisely why you shouldn't use it, and if you do then you'll know why you shouldn't use it.
Happy to be proven wrong gasman if you tell me what regulation it is. I've double checked BS7671 and can't find any reference to it. The only reference to a circuit protective conductor that cannot be identified as anything other than that at termination is a single core cable, the reason being I would imagine is to stop anyone cutting through it kid way through where it is not clearly identified. The cable is double insulated, so is the programmer. A bit like any appliance with only 2 cores, double insulated.
gasmanxxxr1, blue is a line/live/phase colour in old colours. If you taped a line red the blue could be mistaken for a line at the same time. For the sake of a roll of brown insulating tape (or preferable sleeping) just to it right to save any confusion.
Reply to the thread, titled "Is .75mm Five Core Cable OK For CH Programmer?" which is posted in UK Plumbers Forums on Plumbers Forums.
plumbandplumber,
Billy Bob Bob,
