View the thread, titled "Jobs You Won't Do Or You're Considering Not Doing Anymore" which is posted in General Plumbing Jobs Discussion on UK Plumbers Forums.
WaterTight
Subscribed
Leaking pan connector on existing installed toilet.
Did one today. It's the most perfect combination of fiddly, frustrating and filthy.
I made good money from it. But I feel like I need ten showers and some therapy.
Also, the potential with that job to make you tear your hair out is enormous. Flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak, flush, no leak. Put tools away, tidy up, check joints, look down..... One, tiny, evil droplet of water has appeared...
try doing 3 of them, in an abused pub toilet in the middle of bristol, at 12 PM, and still getting the same rate as working in the day. now thats fresh
I hate that with a passion
I don't do anything drainage! Just haven't got the stomach for it! I wouldn't even clear my own let alone anyone else's.
remember starting work for a company in Southampton and they asked me to clear blocked urinals... That was a quick exit!!
i will do anything - but the price goes up with the jobs i hate - that way if i get the job its worth it - if not i don't mind.
i have no problem changing pan connectors (thick bleach down first )
DO NOT DO - unblocking toilets or anything to do with blocked 4" pipework
hate lofts and rockwall -hate it
hate staying home and having no work
If you don't want to get too involved with renewing the pan connectors - especially if some idiot has tiled the floor around the pot, then try this if pan connector is accessible,-
Wear disposable gloves,
Use something, rags etc, to catch any water,
Push two flat blade screwdrivers between connector & pan spigot an inch or two apart & clean + dry as best you can in the gap fully around the spigot.
Use a clear sealant -preferably a polymer type that hardens even if under water. Keep the nozzle well into the gap, put plenty sealant in & move nozzle around the connector. Wipe excess of outside of connector.
Job done & always works. 10 minute job.
saniflo or toilet blockages i do but charge accordingly, hate them and always feel physically sick, need some bleach and if there are any decent masks on the market would be good to have one !
hate working in lofts, now wear the disposable overalls and mask the lot, hate the stuff
hate installing cheap crap sinks from the likes of ikea which seems to be alot these days
also hate drain testing, everytime you pull the bung out you get a nice suprise
I just wear gloves, take old one off, replace with new one, nearly always have a problem with old ones not sealing again. saves hours of messing around and dont get too dirty too
Best, are you using Plumbers Gold as a sealant for this?
To be honest, even ordinary silicone will work if you managed to get the surfaces dry. I used Dow Corning silicone on a few & it worked. Not much pressure on the joint anyhow, & probably better than new.
I have used Tec7 & similar on them, & frankly couldn't care less what sealant as long as it can harden! :smile:
Don't mind water, sheite, urinals, waste water, rainwater guttering etc.. but!.. open up a grease trap before me and my stomach goes all wobbly!...
Oh.. and loose bath taps and when you arrive you find the bath tiled in...
unblocked a saniflo before in a chinese restaurant, that was disgusting, was used for all the waste and fat from the food
Decomposing food has got to be the worst smell ever, that sickly sweet smell, a bit like a decomposing body if anyone has had the misfortune to have come across one..
I know what you mean, but what if you go to an old loo, rusty screws to floor, tiled around base, & perhaps even the soil pipe angle wrong - so a bit of a botch. Maybe also customer has little money & you have little time. Quick remedy just to use sealant.
Perhaps the most repulsive job you shouldn't really go anywhere near is attempting to fix some cowboys work that your customer had previously deliberately give to the cowboy rather than you. Especially if they had paid him more than you would have charged!
Ah...that dreaded droplet, we meet again my old friend.
I've been known to Denso the odd 1960's dripping toilet, give them a choice of course.
Best I'm interested in this because it would save time and faff. But I don't get what you're doing different to other people who attempt this. Because I've lost count of how many times I've gone to one and been told the previous plumber "put some sealent on it" and a few days/weeks/months later it's leaking again. I'm sure they usually squeeze it between connector and spigot and I'd have thought most would think of trying to dry the inner surfaces. So what is different about your method that makes it work every time? Is it the screwdrivers? The type of sealant?
I hated doing the job today and so a foolproof way of sealing it up in situ would be something I'd love to master.
Reply to the thread, titled "Jobs You Won't Do Or You're Considering Not Doing Anymore" which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
Thread starter
WaterTight
Subscribed
Joined
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Thread Tags
Tags Tags
None
WaterTight,
Mickyplumb,
