Hard to say without seeing it in the flesh so to speak but I would imagine a couple of hundred quid
Photos of radiator as requested. Also slightly concerned because the installation manual states that the external condensate pipe must be a minimum of 30mm before it passes through the sleeved wall.
My pipe seems smaller. The list is never ending :whatchutalkingabout
View attachment 24366View attachment 24367
As mentioned yours is 30mm by looks of it. Out of interest read a few lines down as the current Logics state external condensate pipework should also be insulated with weather proof insulation (type o) as a further precaution against freezing.
I have came across a few 30mm condensates freezing solid over the years.
Hello,
This is my first post and I hope you could offer me some advice please.
We recently had a new boiler fitted, the boiler and radiators are working well, but the finish is awful.
The Condensate Drainage Pipe runs externally to the soil pipe, not ideal, but were having a conservatory fitted over it.
This pipe is now leaking from the joint where it meets the soil pipe and also the elbow and other joints. The plumber is avoiding our messages and to be honest I would rather ask someone else to do the job.
I have attached a picture of the pipe, I'm no expert but should it not be one pipe at an angle?
Please could you offer advice on what I should be asking a plumber for, I need this pipe to be water tight, as its going to be boxed in in the conservatory which is supposed to be getting done in the first weeks of January.
Thank You in advance (sorry I couldnt rotate it!)
Nat View attachment 24249🙂
Looks like a plumber who forgot to bring solvent weld glue.
When I say sleeved I mean the copper pipe should be run through the wall in a sleeve made from plastic overflow pipe. This is a regulation and prevents chemicals in mortar and plaster from reacting with the copper pipe which over time causes pinhole leaks
I think it's more to do with movement and abrasion mate
Well the plumber got back, he feels the condensate pipe is perfectly suitable, as he has installed 100's like that. They do have leaks where the glue needs resealing or the glue hasn't set.
He is coming to glue the pipe as needed. However I would feel more confident with one diagonal pipe. What would you recommend I ask for? Just a glue or a new pipe?
Thanks again 🙂
Thanks again 🙂
New pipe outside as well as it looks a mess
Remember your rights:
1) As a trader, he must perform the service with relevant care and skill, and within a reasonable time frame. Also, information said or written is binding, ‘where the consumer relies on it’.
2) If any of the parts of his service is below standard, you as the consumer are entitled to ask for him to either redo a part of the service or complete the whole service again for free.
3) If the service cannot be performed within a reasonable amount of time, without causing inconvenience, you, the consumer are entitled to ask for a price reduction – in some cases up to 100%.
4) He has only one chance to redo a service to the customer’s satisfaction.
You have all the advice and list of items here, so go through this thread again and make the appropriate notes.
a) Give him the full list that you have from here, including the requirement for the Benchmark report PLUS a copy of the Building Regulations notification that he has to have filed.
b) Advise him that if it is not fixed properly (all the items) first time to YOUR satisfaction within a reasonable time - agree ithe timescale with him, that you will get a third party to fix it and reclaim the costs from him.
- If nescessary to get redress, you can easily contact GasSafe and raise a complaint (too few people do 🙁 )
Thanks Worcester. I will be asking for replacement of the condensate pipes, I am anticipating he won't be happy with this, so if he doesnt I will explain that I will be seeking a refund for the cost of the repairs.
Whilst I'm here, could anyone tell me how I would attach foam insulation to the pipes where it meets the wall? Does it need sealing or anything? I'm such an ammateur lol.
Thanks 🙂
C
C
