WHPES
4,830
590
113
North Yorkshire
Got a customer with a macerator which runs from an en suite at the far end of the building into a loft space, then outside to a soil stack. The pipe froze up and they are wanting to re-route it inside the house under the floors. It is a Saniflo Plus unit draining basin, WC and shower. The run would be about 20m more or less horizontally.
The problem we have is the Saniflo booklet states a 1 in 100 fall and solvent weld 22mm pipes with slow bends. This would be impossible under the floors as
a, the most fall I could achieve is 1 in 200,
b, the pipe would have to go up and down over a steel beam about 2m from the saniflo,
c, the only pipe we could get in the space available and round the corners would be flexible polyplumb but the instructions say not to use push fit. I presume the reason behind this is the inserts snagging solid matter and causing blockages?
d, space constraints mean that some bends would have to be 90 degree elbows.
I am stumped. Anyone got any other suggestions?
Why not make sure the existing horizontal pipework in the loft space has a good gravity fall all the way to the soil pipe any exposed pipes are lagged properly.. also once you go over the top in the loft you can step up to 32mm pipe.
Push fit is not used as it could blow the pipe work apart with the associated mess involved also never try to pump downwards creating a trap in the pipes it overloads the pumps also when the machine has stoped pumping the contents seperate causing the pipework to block over time. By the way 22 mm pipe work required for the machines to work refers to the minimum inside diameter required not all pipe is equal !
If you use a continuous length of speedfit pipe hen there is no risk of a joint breaking as there arent any! Additionally if you then get a blockage you can stick a hydraulic tester on the saniflo end and pump it up to 10 bar to blow out a blockage and it wont burst, you certainly cant do that with 21.5mm glued waste. simples
The blockages are generally in the machine unless the pipework is full of 90 degree bends & has not been de burred properly or restricted joints caused by excessive glueing,
I suppose thats where Mr benuli's principal comes into play to really screw things up ...........
With one peice pipework thats fine as long as its supported in an appropriate manner to prevent it sagging and causing traps in the pipework that over time will block up I prefer 32 mm solvent weld or 22mm copper pipe but there you go.
The reason I said take it up in 22 mm copper and as you go over the top on the fall to the soil step up to 32mm is to create a break for the machine and make it easier for it to pump also syphonage helps to empty the machine and as long as the water trap in the machine & pan is not being sucked out thats good in my book.
You can always use your Aquavac to suck out any blockage in the discharge pipe.
I like George to suck up water, I prefer leaving customers opooh to them and not having the resultant stench in my van, not nice when you go to the next boiler service.lol
Didnt think Henrys liked to be wet ? Charlie is a better bet, Empty it down the bog & Clean the machine at the customers house after use and sanitize why carry customers cack around ugh !!!!
