Mains hot water cylinders
View the thread, titled "Mains hot water cylinders" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
B
Blackrod
I'm in the process of fitting out a new airing cupboard and replacing our old open vented ho****er system,
and I am considering using a main pressure hot water cylinder, any one had any ploblems before I commit £500 +
Regards
Regards
You'll have a problem if you try fitting it yourself. They're complex and potentially dangerous if fitted incorrectly. You really need to be qualified to fit one safely.
Upvote 0
Need good mains cold water supply.......! Preferably 20mm plus!
Need a means to accommodative the safety discharge pipe!!
And you need someone qualified to install commission and register the installation with the local authorities!
Upvote 0
Hello they are the best for hot water due to the high pressure, and i agree to the other posts on this thread they can be very dangerous if fitted wrong and you need a good incoming water pressure. You only get out what you put in!!!!
Upvote 0
Reply to the thread, titled "Mains hot water cylinders" which is posted in Plumbing Advice for Any Other Country on Plumbers Forums.
Blackrod,
TBServices,
