Is is ok to go from 15mm to 10mm bore then 15 again when connecting to one small bedroom rad? The feed & return pipes across the landing are 15mm, spur feeds are needed from these to a new rad in the bedroom. There are 2 steps up from the landing to the bedroom, there are existing unused 15mm pipes running from the top of the steps and a short way under the bedroom floor boards, they need connecting to the F&R & extending under the floor to near the rad probably with plastic/pushfit, the final connections from under the floor will be by 10mm as it's easier to conceal. Would it be ok to run the spurs as 10mm as they need a few turns to negotiate under the steps & 15mm is a bit lumpy?
I can add a diagram, just not sure how to attach..
