May 11, 2019
DIY or Homeowner
Hi there,
I need to replace my bathroom sink mixer tap but can't remove it from the sink for the life of me.
I've uploaded a few pictures of the tap from various angles. There doesn't seem to be any screws or allen key points.
Has anyone seen a tap like this before and knows how to remove it?
Many thanks
Matt
Hi there,
Many thanks
Matt
Underneath at the rear will be
usually a couple of flexi hoses supplying live
hot and cold which will need isolating. Then there will be a hexagonal long nut which can be undone using a flat head screwdriver usually, then you can withdraw the assembly from the top. Centralheatking
you can use a mirror to check otherwise do as RPM
suggests
J
UK Plumbers Forums
Deleted member 120897
