If you want it that thick then have radiators, sod all point of having ufh.
if you're having them for sound proofing then invest in floor stuff.
I have seen lots and lots of the solid wall insulation jobs at a standstill due to running out of money.
By all means apply for green steal. But don't pay upfront for anything as they will just take you for a ride.
I have a three story Victorian house, I bought seconds of celotex from eBay. I bought 2 lorry loads at £1000 a pop. Something like a million sheets of 100mm.
I dry lined whole house with a ventilated gap behind insulation of 50mm. All foil walls , 99% air tight as all the studs and foil sheets were covered with foil tape.
Celotex in ceilings again 100% vapour barrier and the ground floor I removed the concrete and excavated 350mm and then built a suspended timber floor with 100mm celotex between them and then out wet ufh on top of it.
My loft has a lot of insulation too. It's a warm roof.
I don't think your builder or the green deal will take as much care with insulation.
Your heating system?
Defo ufh ground and bathrooms
Rads on zones above ff.
Unvented.
Don't think ashp is what u really need when on a budget. Solar thermal for your DHW.
Use a decent unvented ACV SL or similar. Pipe your house so that a everything comes back to a "low Loss headder"
Have two spare ports so that an alternative heat unit can be added into system at a later date but for now just hook up a gas boiler / if you can't afford the whole Hogg
Oversize your rads by the same amount say factor of 2 .
I would make the system as versatile as possible .
Get Worcester round to have a look he's the main man
Ermi where you get the seconds insulation at that price I need a lot of it
eBay. It's the one in Wales . His name is rob, call up negotiate and your away. Weekly drops to the north easy. Bought mine 6 years ago! He will bond it to plasterboard even double thickness.
A&A insulation 01443 209585
Or the main man
Robbie 07717805726
I didn't give anyone his number and it's a need to know basis.
A decent system boiler and an unvented hot water cylinder sited in the middle of the property landing somewhere as Killy Bing stated
But the opinions for prices I've non of any ideas
Try these as well: Insulation Boards
Just spent the day at Stiebel Eltron, they have a nice range of fan assisted rads for heat pumps, not quite as stylish as the Dimplex ones though a good solid brand, with much better support and backup.
Designing for a heat pump, at a flow temp of 40° the rads need to be 4.3 times bigger than with a delta T of 50° ! So fan assisted definitely helps.
Omg Worcester / Gordon I always thought you were a nice sensible chap, "forced convection rads" horrid nosey dusty rubbish. May as well just go warm air and be done with it.
The large open space at the back of the house has not been fully knocked out yet and will be divided into two living spaces as well as a downstairs toilet and utility.
There will be 1 bathroom with a bath as well as a shower. another ensuite on the first floor with a shower as well as a shower room on the second floor.
Conservation officer coming today so should know what my limitations are.
Effectively the job is now stopped, conservation officer in Wolverhampton are you sure, have they got one. 77 posts and not a pot washed, Chinese Knot weed, bats and newts all you need now is a tree huger, send us the postcode and we will Google map it see if the lads can throw some light on it for you, if you knocked it down and rebuilt it do you think anyone from the Corpo would notice.
On the contrary Happyflyer.
He only said that we should not replace any of our existing wooden windows to UPVC. I just though it prudent see approval rather than do what i want and then have the council servicing me orders to remove stuff and threatening all kinds of action. If that makes me stupid, then so be it.
I can see that me posting on this site is starting to annoy you so I will stop posting and asking questions.
Thanks to everyone who has provided good advice to a member of the public who just wanted advice from experts.
On the contrary do not stop posting is very few times we see someone get to the end and come back and tell us how it all went its just I am 70 this year and don't know if I will see you completed at this rate, I want you to get a move on and start making some decisions please, lets see some action winter is coming
Tony
