M
Mike Jackson
Sorry but the maximum 1mb pressure drop for domestic installation is based on the premis that the minimum supply pressure at the meter is 19mb this is to guarantee an absolute minimum of 18mb at appliances.
If you have a higher starting pressure from the meter eg 75mb (which is the top end of the Low pressure scale) in the service pipe then you can afford to lose 53mb over the 180 metres in this case .. and then install appliance regulators to control the appliance pressure as required.
Someone with a mears wheel might calculate the pressure drop over 180 metres of (say) 28mm pipe at 75mb
This is effectively what the gas supplier would be doing by fitting the meter and governer in the property but with the huge advantage that they have responsibility for repair or replacement of the pipework up to and including the meter. As a domestic gas safe registered installer I can work on natural gas at 21 +/- 2 mbar and LPG up to around 40 mbar. Working at higher pressures will require someone with a commercial ticket and maintenance costs will be vastly higher. The only sensible way of dealing with this is to have the meter in the property or look at alternative energy sources.
