View the thread, titled "New reliable combi, what would you fit in your own home." which is posted in UK Plumbers Forums on UK Plumbers Forums.
My local merchant
Or rather My local independent who was 80 quid cheaper than the merchant
is that including fitting kit ? found this one online, as no merchants near me supply intergas yet, looks a good deal ? [DLMURL="http://www.hpwarehouse.co.uk/intergas-combi-compact-hre-2418-condensing-boiler-1978-p.asp"]Intergas Combi Compact HRE 24 18 Condensing Boiler[/DLMURL] £586 +£42 for kit + £48 for flue + 34 del +vat 852.89
only one thing i can find wrong with the intergas(and no i dont believe the ten year bull crap) it has a aluminium silicate heat exchanger just like ideal and wb ............no thanks
My opinion, you my worcester cdi has not flickered in over 4 years. However I'm more a baxi installer, good price cheap parts and good after sale support. You can't ask for more. Maybe a longer warranty! Same goes for blot of the big players.
I was interested in trying one of these out, but after hearing that, to quote Duncan Banatyne "Iam out".
From a trade point of view i'd sell you whatever boiler you wanted but usually talk you round to the usual (quite) reliable suspects.
Personally i would buy the cheapest long warranty boiler i could get.
When it breaks down after the warranty bin it. (but i don't need to worry about install costs)
Any boiler, no matter how cheap or expensive, will do as it says on the tin but things to consider are.
Some are more reliable than others. (google it)
Some have longer warranties (usually requires regular proven services for these)
Some manu's offer better/faster service than others.
Some parts are more readily available than others
Cheap boilers are generally expensive parts/repairs.
They will ALL break down at some point.
They will all have a higher lifetime ownership cost than the old lump of cast you are replacing.
If telly's were as unreliable as boilers there would be a national outcry.
Pay your money take your chance.
Btw.
I have an Ariston ??? system boiler in mine (how embarrassing (not for being an Ariston, i couldn't care less what it was) i can't even remember which one because i've never seen at it since i fitted it).
I got it cheeeeaaap.
images
Intergas heat exchanger has copper pipes running through for heating and hot water the Ali does not come into contact with heating water/ hot water.
I had a meeting with the rep yesterday and they are offering full 5 yr installer warranty subject to going to Bromsgrove for a course (free like viessmann). 10 yr on the H/E
Got a 24/18 combi, vertical flue with lead slate flashing kit, remote fixing kit and outdoor weather comp sensor for £832 inc vat
They will have a wireless stat available shortly
Baxi Duo Tec, got one in my house- excellent boiler
I have fitted a lot of Ideal Logic+ boilers, I think these still come with a 5 year guarrantee. Get your installer to check your water main pressure and flow rate, if it is sufficient over 15 litres per minute then go for the 35Kw model.
hi ecowarm where did you get your intergas 24/18 combi, vertical flue with lead slate flashing kit, remote fixing kit and outdoor weather comp sensor for £832 inc vat. i'm looking for same, to replace my ravenheat csi 85t (junk) thanks in advance
PM sent Bill
Surpriced I'm first to say Main. Cheap, simple, reliable. If I had the extra money I may fit a Worcester CDI. The Main and Worcester customer service is amongst the best out there and their reps have done great favours for us so I like to maintain these relationships.
dont forget genguskarn you will more then likely need your system flushing/cleaning as well.
i have a baxi dutoec in my house and its what i recommend to my customers ,
good luck
Reply to the thread, titled "New reliable combi, what would you fit in your own home." which is posted in UK Plumbers Forums on Plumbers Forums.
