Also you shouldn’t be taking the case off the boiler to fit your stat. YOU ARE NOT GAS SAFE REGISTERED.
You also cannot get all documents on the day. The boiler has to be registered with manufacturer and gas safe. Paperwork takes a few days normally. Also definitely no powerflush there. Any filters?
No filter mean no warranty. They need to fit a filter.I gase safe cert, boiler was registered on the day with baxi andgas safe register, i will have them in the post, no filter.
I had a gas safe cert, boiler was registered on the day with baxi andgas safe register, i will have them in the post, no filter.
I never removed the boiler cover just 'dropped down' the the bottom part to remove link/fit stat...
I'm a spark, how many plumbers on here are Part P or similar to connect the mains ??
The first thing they do now from what I am told is a water check? Not sure it will be clean enough in 2 hours?In theory if cleaned and inhb installed there's no need for a filter but it's worth a 100 just for peace of mind
Warrenty ok with no filter aslong as system is cleaned / clean
Jumped the gun a bit there. Sorry. My bad. Forgot that Baxi have the drop down pcb and seperate combustion coverDon't need to be part p unless your fitting the fused spur from that were fine to wire
I have seen companies honour warranties with dirty water because a magnetic filter has been fitted.You mean inline scale filter or magnetic filter? Having no magnetic filter doesn't void warranty even tho its good practice to fit one...system needs to be crystal clean mind. Don't have to fit scale filters down this way so not sure.
Reply to the thread, titled "ADVISE PLEASE - What replacement boiler for Ferroli DOMIcompact F24B ?" which is posted in Boiler Advice Forum on Plumbers Forums.
