Ok, get a traditional mop, not the blue silly things, but the string ones wet the mop head, flush the bog, and put the mop head into the pan and pump it up and down as deep as it will go ..keep adding water, the hydraulic traction you will get is massive almost as good as a machine. make sure the mop head is well fixed..it usually works but my mrs wont use her mops after they have been out with me...cant think why
good luck ..centralheatking
Of course there are many ways to unblock the loo but the issue is, I shouldn't have to do this every flamin' time someone does a number 2.
My missus seems to be blaming me for all this though of course its always me with the rubber gloves, plunger, drain wire, washing up liquid, hot water, bleach etc. I am blumin sick of it. So I guess removing toilet and starting again with the waste pipe work is the only solution.
if you do as I say it might solve your problem altogether chking
of course your mrs blames you, durr thats what they do, man up and solve it ...or retrain your mrs in some other way..apprentice plumber ?
  • Dislike
Reactions: rpm
No nothing lost down it. Not sure what you mean by "the same run" but no other sinks, toilets, baths or showers in the house get blocked. I am starting to think it is the waste pipe work that is causing the problem.
Reactions: Burger
Same run, is other outlets connected to the same soil pipe/drain. Eg wash basin, etc. From the sounds of it then yes it could just be the soil pipe it’s connected to. I recommend removing the toilet suite and look down the pipe before making any decisions.
  • Agree
Reactions: Best
Yes there are many ways to unblock a toilet, but Rob was suggesting this method because it isn't just poking at the blockage, you get a good blast using a mop (I tie a carrier bag round the mop head to help the seal).
When you're poking it with a wire you're probably making a small hole, the springiness of the wire will mean it will only hit a small part of the pipe after a bend no matter what you do with it.
Pouring water and or chemicals down is only using gravity to try and clear it.
Try the mop trick, it has got a lot of plumbers out of the poo a lot of times.
Reactions: Burger and Best
This method requires more skill but if you don’t have a string mop this is free.
Stand on a chair and quickly pour an entire bucket of water from ceiling height.
Stop mucking about with a wire. As JC says above, you are at best poking a small hole in blockage - the bucket or mop methods provide a means of moving the whole blockage along.
Lift the nearest manhole and get someone to watch, keep going with whichever method you choose until they report that they have seen said blockage go sailing by.
As you say you shouldn’t have to do this daily - you won’t once you have done it correctly eg as above.
I’ve had this problem before. Found it to be where the pan connector fits into the bent pan connector. If you remove these fittings you’ll see the problem. You’ll need to cut off a bit of the pan connector so when inserted into the bent pan connector (periscope) it doesn’t insert so far as to reduce the bore of the pipe. Hope this helps
Many thanks to all who have tried to help. Dave Banfield's idea seems very plausible. I have ordered a new waste connector which is slightly longer at the top (where it joins to the toilet outlet) so hopefully the toilet will plug straight into it without the need for the extra joint which I have at the moment which seems to be causing the problem.
Thanks for suggestion, Ben. When using whatever method the blockage eventually gets completely cleared and the toilet drains perfectly with liquid and paper flushing away nicely so all is great until someone does a number two then the toilet becomes partly blocked yet again. It will flush and the water goes away but slower than it should. I think there is a problem in the way the pan connects to the waste so I am going to have to dismantle it and see what is what. I will post with what I find.
Ah ok I didn’t realise you got fully correct function each time.
In that case sounds like a connection problem, I had this once and it turned out that the rubber seal from inside the pan connector had come partially away from its correct position, such that half of it was inside the 4” pipe.
The paper then snagged on this and caused a blockage, amazingly it didn’t leak otherwise I would have found it sooner.
As you say next stage is dismantle and inspect.....
Cheers Ben. No one is using the loo except for wees and tomorrow I will take it to bits and report back. Really appreciate the support from everyone.🙂
Can't beat a bog in a box with a deep pan hole for getting no2 away. Some modern toilets are only designed for small turds.
  • Agree
Just bought two from homebase, £45.00 each and I know they will flush away because I have 6 others. Saves cleaning etc after every dump as they flush down clean every time alot of designer stuff is crap. no floaters left with these bog in a box bog pans. We used to get thro loads of asda bog brushes at the holiday lets then I re fitted
happy...CLEAN...days
