OK so I fitted the replacement waste. Couldn't see anything obviously faulty with the old waste. Anyway, cautious thumbs up for now. A number two done and successfully flushed. Even when nothing in the toilet the water now just seems to disappear much more quickly when flushed. Anyway, we shall see what happens over time. Thanks to all who have tried to help.😀
Hopefully fingers crossed it is the pan connector. I have seen this issue a few times by someone not setting the correct water level in the cistern. Or the other one the customer doesn’t realise it’s a duel flush and flushing with reduced water with number 2’s.
Just thought I would mention it if there is still an issue.
Years ago we use to use the Silicone grease for any 4” pipe work or toilet fittings.
As I haven’t done site work for a lot of years and no longer have it in my bag I have since used a small amount of jet blue. It seems to work well. I even do the same with flush cones.
Thanks for your interest. The toilet now flushes normally so it is obvious the waste connection was the problem. As I said much earlier in the thread when I first fitted the toilet the waste output from the toilet didn't quite reach the plastic waste input so I used a small extension. It appears this was just too much for the flush to deal with so when I replaced that waste setup with a single fitting everything was fine.
Reactions: Rob Foster and rpm
Hi to all. I have just signed in because of a plumbing problem. I am a DIYer and have no plumbing qualifications but I do have common sense and follow instructions.
I have recently replaced a close coupled toilet which worked fine with a much more modern looking one which seems to clog up if anyone does a number two. The poop always disappears but then the toilet takes a long while for the water to drain when flushed so it is a partial blockage.
When I fitted the pan the spigot did not quite reach the plastic waste outlet which is the one that looks like a periscope. My local plumber sold me a small extension so I could connect the spigot to the plastic waste. All seems to work except it keeps blocking.
1. I am wondering if the poo is not quite passing through the extra pipe or getting caught on the joints?
2.Should I go for a flexible connector?
OR
3.I have found that Macalpine do a connector that is slightly longer at the top which might fit my toilet without the need for the extra joint.
4.None of the above?
By the way the flush mechanism is properly set up (followed instructions)
and the flush appears to be nice
Clogging is the number one cause of toilets flooding in many homes. This is a situation that occurs when the toilet is filled up with the wrong items. Your toilet is designed in a way that it can only accommodate and flush waste and toilet paper. Any other unwanted item may easily clog your toilet drainage system.
Dumping nappies, sanitary products, solid items, and paper towels can easily clog your toilet system leading to water overflow. And even before you start claiming that your toilet overflowing for no reason, clogging can occur in many forms. They include;
  • Clogged toilet bowl – Most of the problems in toilets are as a result of a clog in the toilet bowl. Don’t flush down wrong things that may easily clog the toilet bowl and lead to unnecessary problems.
  • Clogged toilet trap – Most toilets have a toilet trap that helps prevent sewer fumes from going into other rooms and cause terrible smells. It is easy for this trap to get clogged if the wrong products are passed through it.
  • Clogged drain pipes – Flushed water flows into the drain pipes then towards the sewers that have multiple bends that can easily be clogged by wrong items. With time, the water will be flushing slowing and eventually, the issue will become a severe drainage problem.
  • Clogged sanitary sewer – Flushed water from the toilet also drains into the lateral sanitary sewer line that is connected to the main local sewer system. Wrongly drained items usually clog the lateral sanitary system leading to toilet floods or overflow.
There are many ways to unblock a drain:
  1. Use Boiling Water
  2. Use A Hosepipe Or A Hanger
  3. Use Of Coca Cola
  4. Wet And Dry Vacuum
  5. Use Vinegar and Baking Soda
