Not without knowing were the pipework is which is doubtfull considering its concrete as mentioned are all the downstarirs floors concrete?
No, just the bathroom. But thinking about it possibly the kitchen as well... The main building (the bathroom and kitchen are on an extension) is Victorian and somewhat higher than the extension. I'm crossing my fingers that there's enough space here to get under the floorboards.
The plumber could isolate the downstairs pipework then carryout a hydraulic pressure test which will hold a test pressure on the system and any leaks would be seen by a pressure drop on the guage. This would be quicker than just leaving it on the system for a week.
When my heating system was installed it took a few top ups as the system stabilised over few weeks. It is now fine.
Do you have thermostatic radiator valves on all your rads? If you have and they all shut down, and there is no bypass in the system, the boiler can overheat and will dump the pressure out the relief valve.
I am sure he would have checked that though.
Good luck
You can find out if its leaking on the flow or return by shuting off one valve on one side of boiler and all rad valves pressure it up and see if it drops then if not do same for other valve on bottom of boiler.
Good luck
Thanks very much. I will see if anyone in the area will be able to do that for me. Yes we do have TRVs, but considering that one of our rads on the top floor drained empty during the last pressure loss, a leak seems the most likely cause.
It appears the system has been upgraded> The installer cannot be held responsible for underlying issue. I get this situation all the time when systems go from open to closed. I would suggest that you Google water leak detection and get someone to trace the leak. The re-piping is a load crap sounds more like trying to make a bit more work for himself. I would also suggest contacting your house insurance as most will cover this type of service and any resulting damage caused getting to the fault.
It appears the system has been upgraded&gt; The installer cannot be held responsible for underlying issue. I get this situation all the time when systems go from open to closed. I would suggest that you&nbsp;Google&nbsp;water leak detection and get&nbsp;someone&nbsp;to trace the leak. The&nbsp;re-piping&nbsp;is a load crap sounds more like trying to make a bit more work for himself. I would also suggest contacting your house insurance as most will cover this type of service and any resulting damage caused getting to the fault. <br><br><br>
I was reading those 7 pages before this and was wondering why no-one mentioned a pressure test until plumbsy's post. If i'm upgrading from ov to sealed I always describe the dangers and offer to do a test at quote stage for £50, refundable if I get the job.
Good idea, never even considered that previously. I always go with the statement on the estimate about not gauranteeing existing pipework.
The way I see it the customer is more inclined to accept my quote if they think they've already paid £50 towards the final cost. If they don't accept my quote they've still got something for their money and I haven't totally wasted my time.
That is a good idea, but I can imagine there is more work involved in testing it than you first think? Do you hydrolic test it or just pressurise it with air or something?
Hybrid,
I would agree with you but we always asume a plumber has confirmed the fault by pressure testing the pipework before we visit a site. It would suprise you how many guys including old hands cant be bothered to do a pressure test.
It doesn't surpise me Leakfinder lol. A lot of people spend so long thinking of creative ways to establish if there is a leak they'd be quicker just testing it in the first place.
Arran I hydraulic test it.
It takes a bit of time but it something i'd be doing if I get the job anyway and it usually sways a customer towards using me. I spend the test time discussing the install with the customer. I get paid £50 to quote lol, wish everyone would take me up on the offer.
I got called back to combi conversion the next day 9pm , water dripping though the celing , ripped up hallway floor boards, no where near my work , found a pin hole in hot pipe to bathroom , it was like I tiny jet , must have been leaking a good 24 hrs , cut out hole , repaired ..
J
J
