View the thread, titled "No hot water on gravity system?" which is posted in Bathroom Advice on UK Plumbers Forums.
Get a bit of hose pipe go up in your loft and go to the bigest header tank and the pipe that bends over it put the hose pipe in it and suck till you get water out this should clear the airlock. How old is the boiler?
If it's a gravity system it will only be so air lock if it's been drained recently. Most likely cause is a seized ball valve in the f @ e tank. The water is lost through heat evaporation.
Sorry folks. This isn't a job I've been to as yet. I'm going to look tomorrow. I am in the trade but still very new to it. As I haven't been to the job I assumed an air lock or the gate valve on the cold feed to the tank is stuck shut.
Someone has changed the ladies cold feed tank which apparently just serves a hot water cylinder I haven't been told anything else.
That's why I thought about getting a little heads up.
Ok. I know it's definitely something with the recent work. The vague info I've been given leads me to think a gate valve has failed. I'm sure the chap said he's turned the immersion off.
good call but it may be a tad easier to cross kitchen taps and blow back mains into hw tap back into tank..brum
If it is just a simple air lock in the hot pipework (probably cold feed to hot cylinder) then just put the cold through the hot. I do it on the bath mixers where the cold & hot are both from gravity (cwt) supply. Even though they are basically the same pressure, if you open the hot tap on a bath mixer & holding your hand over the outlet, just turn cold full on & hold for about 10 seconds at least & air is blasted up the cylinder feed.
Other sure way is to join hot washing machine valve to the mains cold w.m. valve using a w.m. hose.
Or remove the neck from kitchen sink mixer & hold your hand over the hole while turning hot & then mains on. You normally cant keep the neck in as the neck divides the supplies on modern mixers.
Put your hand over the spout of the mixer tap and open the hot first , then open the cold , because your hands over the spout it forces the cold up the hot side in turn moving any air , if that's the problem this should help mate, you might get bit spray on your face but it works lol
No water through the tap? Scaled up hot water outlet on the vessel. Not heating up on the gravity circuit? no water in the primary flow and returns.
Reply to the thread, titled "No hot water on gravity system?" which is posted in Bathroom Advice on Plumbers Forums.
Thread starter
macka09
Joined
Thread Information
Title
Prefix
N/A
Forum
Bathroom Advice
Start date
Last reply date
Unsolved
macka09,
kay-jay,
