View the thread, titled "No Hot Water" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi
We've recently had an issue where our hot water was fluctuating hot to warm and occasionally cold. We got a Britsh Gas engineer out and he changed the heat exchange plate but noted that the main heat exchange had sediment in it also and said it would need replacing or maybe even just buy a new boiler.
That said, when he left we had hot water and it was perfectly fine for showering etc.
Two days ago we had a total loss of hot water, we've since had another engineer out via our home insurance. I told him all the above and he's just put it down to the same. I regret telling him now as I feel it would have been better for him to form is own opinion without my help.
I know it's idiotic to doubt the advice of two trained professionals but here's whats bothering me.
1) The heating is rock solid, it gets up to temp and stays there no obvious signs of any issue.
2) Would a blockage like they describe just go from the hot water working inefficiently to completely not working at all, especially given the plate exchange has been changed?
3) The boiler (Glow Worm Betacom 24) is giving an F23 error (Maximum temperature difference reached between return and flow heating) water circulation fault.
Before I pull the trigger on a new boiler could anyone offer a 3rd opinion on whether it does sound like its just build up in the main heat exchange that's causing this
Cheers
Any reason why you got a bg engineer ?
was struggling to get a local guy out same day,
Follow up to above, we've just noticed the radiators are a little warm when the heating is off and the taps have been running, would this indicate the a issure with the diverter valve pushing hot water to the rads instead of the taps?
That’s fine so not on a bg plan
Best advice is get a local engineer to have a look
Reply to the thread, titled "No Hot Water" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
Widnes
DIY or Homeowner
Thread Information
Title
No Hot Water
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Tags Tags
water
Gromit77,
ShaunCorbs,
