This is somewhat a bit of a gray area, most new boilers the outer case is just that ! just somthing to look nice, with the combustion chamber sealed inside, according to what GS told me just B4 Xmas a sparks can remove the outer case to gain access to the wireing terminal as long as no seals are disturbed he can also replace the built in time controls, and that is all he is allowed to do ! can-not replace any fuses on the PCB as this is to do with the opperation of the boiler, Proberly ring next week and get told somthing differant.
i dont get you, they would be both breaking the law?
As soon as the gas connection is made the appliance must be commissioned, you can not leave any gas appliance connected to a gas supply that can not work correctly. Therefore the GSR engineer who connected the gas broke the Law. That is why it is in the regs to prevent the spark from being able to turn on an un-commissioned appliance.
job am on now, boiler has flying lead, there is no fused spur, house getting rewire. Will put plug on and plug into extension lead, commission boiler remove plug and then sparks comes in and connects to new fused spur he has installed. if he needs to wire in timer and stats etc he carnt remove cover.
that what i said, did you not see the 🙁 sad face? in my post.
i was merly refering to the sparks and the fact they must comply to the gas regs like everyone else, so if he/she removed the case and then turn on they have broken the regs, to a lesser degree i guess but still dont hold up in court.
Trust me you dont need to tell me the regs about uncommission appliances ive seen enough dangerous situations left by idiots while onsite, thats why i have tons of those uncommission appliance lables on me van along with about 50 meter blanks, you tend to build them up when working on voids over the years.
I do miss reading the threads of DIY gas repairs. But totally understand the reasons for the closed threads. I think a bigger message before you can access the forum would help. I rarely read the blurb at the top of the screen.
Reactions: 4 people
it always makes me laugh when one trade says another trades regulations have nothing to do with them. If you make a hole through a wall you must know the regs on fire ratings wether your a builder,plumber or painter.
Reactions: 2 people
Mushroom fertiliser in my opinion. 😉
can anyone show me evidence for someone doing time for working on household electrics?
is it enforceable or only if some one gets hurt?
no one will goto prison for working on electrics!
if you kill some one then it will be treated no different to someone driving without a licence.
if you work on gas ilegaly then you will.
to wire a boiler you are deemed to be working on a gas appliance, no grey area about it.
to touch the workings of the boiler upwards of from where the pipes enter it..you are working on a gas appliance.
to run a wire, then yeh! sue me. not!!
just a blunt view of it.imo
Reactions: 4 people
I dont see any grey area in it at all anything boiler related is gas works imo end of .
I dont see what the arguement is about on here to be honest from what i gather chris is saying that he wants to give someone advice on working on gas appliances which either A the person is working illegally or B the person is deemed not competant to work on a gas appliance .
ok we all dont know everything but if i was a mechanic i wouldnt encourage someone who is unsure about how to repair their brakes same principle with gas imho.
On a personal note if i am unsure about a repair then i wont do it i will pass it to a friend get someone more experieced in repairs to tackle the job , surely thats the same in recommending a gsr in for the public meaning a competant experienced person .
Please don't put words into my mouth ! The OP was asking why a thread was being pulled & had nothing to do with the right's & wrong's of the advice being given most of which did not even involve me.
I often get shot down in flames on here when I suggest that just maybe there should be restrictions on who should be aloud to practice plumbing & yet here we are with a lot of the same people wanting a complete close shop around this area. Like it or not there are some grey areas (central heating controls problems after commissioning) I am just asking if we are over stepping the mark & should we just blindly take the work of GS who have a vested interest in this close shop they are not & do not make the Law & as ever it is open to question.
This thread has produced several good suggestions on how to improve things for the forum in general. Can I ask that if anyone has a suggestion that they'd like to make to help improve the forum, that they contact the moderators direct. No reasonable suggestion will ever be ignored and we'll discuss it and see what we can do. We'll also email you about the progress of your suggestion.
We're all "singing from the same hymn sheet" and want the forum to continually improve for the benefit of it's members.
Reactions: 4 people
the outer case on most modern boilers is part of the air supply to combustion chamber. If its not put back correctly then combustion is directly affected
Is it un-safe to run them without the casing in place ??
It could become unsafe and it wouldn't be a room sealed boiler anymore.
Most modern condensing boilers have a burner which is under positive pressure. Now if a burner seal was to fail, products of combustion would be entering the room if the case was removed. With the case in place, the products would be contained inside the boiler casing.
Lots of Baxis, Vaillants and Glow Worms have had issues with burner seals failing, I wouldn't like that to happen and have the case removed!
Reactions: 3 people
So what sort of PPE do you guys have to use while you work on such dangerous pieces of equipment ? What is it breathing equipment, CO alarms, heat proof gloves not to mention the heat proof visor just incase the door seal goes when you are having a look. Your risk assessments & method statements must be a nightmare to write. I can understand why there is such a premium paid to GS engineers now it really danger money. :hand:
Come on, you are talking to one of your own now, not a customer. I know my way around a boiler & I am not suggesting that the casing be left off when in normal operation.
