You know what, please do this.
i want to see how bad the thermal shock will be on the news......
1KW - 2.5 KW heat leak rad vs 30 / 50 / 100 KW Heat exchanger ? cant really see your point ?
The thermostatic valve opens at 95 degrees allowing cold mains water through exchanger and to drain. No power required - how exactly is that silly. Trying to dissapate 10KW of heat through a 2.5 KW heat leak rad sounds silly to me.
Contravenes the energy eficiency part of the building regs.
Also what happens when the valve fails?
I'm out
So is the heat exchanger fed off the store via a pump? And gravity off the stove into the store?
It amazes me john that when someone asked for adviceIt's another of those threads I gaze at with morbid fascination!
Can't quite see how the second heat distributing heat exchanger will work effectively. The cold water will cool the heat exchanger, but the stove will carry on heating the store? The heat loss will be negligible.
unless the bottle of cheap 'meal deal' champagne I'm drinking is hindering my reading abilities?
The advice is get someone in who knows what they're doing. You don't need to understand the system.
You just need faith in it. And what you're looking to do I wouldn't put faith in if I were you.
The only problem there croppie is that I would struggle to have faith in the people that say they "know what there doing" when they ;
1) cant answer a simple question i.e. how does a 1KW heat leak rad dissapate heat from a 10KW stove
2) Whilst professing how knowlegable they are - are apparently unaware that this system is fitted to off-the-shelf thermal stores - presumably (but i could be wrong) passing all relevant standards inc. building control and WRAS.
3) Appear to think that Danfoss (and other manufacturers) who designed and made these valves specifically for use with heat exchangers for overhead protection on solid fuel heating systems are "silly" and don't know what they are doing.
Would you have faith in that person ? or the system they installed ?
Hot feed to Heat exchanger is on gravity flow (as is sensor) Cooled water from exchanger returns to gravity return. Difference in temp will increase gravity flow (which would just about stall at 95 degrees) more cooling performed by exchanger the faster gravity flow through exchanger - the faster cooling takes place. When temp goes below 95 in top of gravity flow circuit (hotest part of circuit) the sensor shuts off the valve.
Yep probably more than you
.......so at 95 degrees on one side of the heat exchanger.....you intend to flush the other side with mains water to reduce the temp?
correct?
I thought you were "out" if your going to nothing but critisise why keep posting ? You gave me advise to check out with building control - which I've done - but you can't even wait for the response before you say the system and me are incapable of doing the job !
You havn't even attemped to respond to any of the three questions above - that would be giving advice! so tell me how does a heak leak radiator of 10KW stop the water boiling in a system that is outputing 10KW ?
