View the thread, titled "OK for waste to run uphill a short distance?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
.. and then stare he is going to remove the shower tray and redo it.
Well, if the shower tray is going to be redone, someone's going to have to do it. I certainly don't want to get the previous plumber to do it (and in any case, that ship has sailed now, as I've sacked him), and the new plumber would understandably claim zero liability if the tray cracks on removal, so I don't see what I have to lose by trying to carefully remove it myself?
And if setting it down on a sand & cement base is more complicated that I currently think it should be, by all means I can pay the new plumber to do it. But if I did it, I would follow the manufacturer's instructions regarding sand to cement ratio etc. and would probably do a much better job than our cowboy plumber did with his tube of silicone. I would also use the provided template to cut out the hole for the waste, but would leave connecting it all up to a qualified plumber.
I'm getting back to my original thoughts that he is doing the work himself.
Here we go again... 🙂 If that were the case, why wouldn't I have just come on here and said I'm doing some DIY plumbing? It's not a crime is it? I don't need to hide behind an elaborate story where I'm pretending to be a plumber!
Oh boy get him off the job asap, my 8yr old has better joinery skills. That is some doing...managing to cut every feed pipe such that every braided hose has to be kinked to fit. Ever have to un-kink your garden hose? Well the result is the same if left in place ie restricted or no flow.
If you had come on here and stated you have done some DIY plumbing and posted those pics, you would have got a reply from me ..stating...
Top job Pal.
You've got the talent and expertise to become qualified
You should start doing weekenders for friend, family and neighbour's.
In fact, you should take the pics down to the Plumbing Registration Board, show them what you've done, explain to them that you managed that without any previous experience in the Trade and they will probably give you a Licence.
Once again, beautiful work.
Send some pics in of the completed project and let us know how everythings going in 6 months time
I don't think that hideous shower valve installation is in OP's house or relevant to this thread. That just appeared in the thread for some reason, maybe it was supposed to go in the Hall of Shame? As far as I can tell we are only dealing with the guy's waste pipes and shower tray.
Top job Pal.
Ah, good job I pretended I was a plumber then! Just kidding!
Yes, that's correct. The photo being referred to isn't directly relevant to this thread. The main issues in our bathroom right now are the messed up waste pipes & incorrectly laid shower tray.
Today I spoke with the new plumber and specifically asked how they would go about laying a stone resin tray. I was pleased when he said the first thing they would do is read the instructions (!), but then he said more often than not they bed it down on a layer of tile adhesive. So, I was wondering how this method compares to sand & cement? Of course, in order to be covered by the manufacturer's warranty it has to be sand & cement in our case, but I have read about this going crumbly and therefore wondered if tile adhesive is actually seen as a better alternative by some?
Great well sounds like they know what there doing
Tile adhesive IMO is better than sand cement and will be fine ,.
You can manufacturer and they will say its fine , im fairly certain of that ,
Yea sorry i put that pic up really to show the push fit monkeys about that still cant even do that 🙂
I think once your trays in properly you should be fine
So long as your tiler doesnt start doing things like my next pic
Hahaha! Wow, that is something! I can't even get my head around how someone could do such a horrendous job..
Its amazing isnt it
How the hell do you achieve that , look at the slithers in the corner ,.
Im pretty sure its harder to do what they have done than do it properly in the first instance
The customer wouldn't let me damage the towel rail and the screws holding it in place were seized solid, so I tiled round it. They also more-or-less threatened not to pay if I wasn't done by 5. So I did what I could...
Yep that's good flexible tile adhesive, what did he say about the other stuff ?
He's going to take a look at the wastes on Mon and figure out how we can redo them, but was in total agreement about uphill run becoming a trap for toothpaste, oils, hair etc. He was also a bit shocked to hear about how the waste had been run through the joists, and has suggested adding some more noggins to spread the load. However, he said that we might be ok, partly because building regs have to be overly cautious and also because our house was built in the 1960s and probably a lot less flimsy than some new builds.
OK, quick update. I popped down to Screwfix this morning and bought a pry bar and have spent the last couple of hours nervously cutting away small sections of the OSB around the shower tray with a multi-tool to allow me to get the pry bar under it. I also had to chip away the plaster where it came right down to the tray. Then I went round the tray and gently applied pressure at various points. It was quite nerve-wracking but the good news is I managed to get the tray up in one piece! (Before anyone jumps down my throat, I explained in an earlier post why I decided to do this myself rather than leave it to the new plumber).
The pry bar caused the edge of the tray to chip in a few places, but hopefully the tiles will hide these.
As you can see from the attached photos, our cowboy "plumber" used a few blobs of silicone, so the tray wasn't bedded down on anything! He also cut out a massive hole for the waste, so the tray was completely unsupported over that area.
I'm now planning to take up that section of flooring and put down a new piece of marine ply or OSB, clean all the silicone off the tray and let the new plumbers install it properly.
Any tips for getting the silicone off the base of the tray? Presumably it doesn't matter if there is some residue on the tray, as the sand & cement (or tile adhesive) will level things out?
Great job mate
What a clown , didnt even figure of six the silicone ,
The tiles and silicone finishing seal will cover them chips around the tray ,
All in all id say your good to go , bit of ply and a nice neatish hole for the waste ,
Id def spend a tenner on some ct1 or sticks like , for running round the underside of the waste to tray seal , it also helps it stop moving (depending on the waste finish) if people stand on the waste when showering , if you know what i mean ,.
Well worth doing , you will sleep easy knowing its all done correctly ,
Multi tool and an old blade to get the spots off
How did it lift once you got underneath it ? Doesn't look like it stuck
I sort of gently prised it up a few millimetres at a few points around the tray, then gradually built up the courage to apply a little more pressure. Eventually, on one attempt, I heard the sound of some of the silicone slowly tearing away from the flooring, so I went round the tray trying to repeat this at various points.
I also went along the two straight edges with a multitool to cut through the bead of silicone holding it to the wall as well as I could.
As the tray came up a few more millimetres I placed some magazines below the tray at several points to hold it up. This meant I could get the pry bar a little further under the tray to stop it slipping and chipping the edge of the tray.
When I was able to lift the tray a couple of centimetres, it started to hit the plaster that was overhanging the straight edges of the tray, so I used the pry bar on its side between the wall and the side of the tray to gently pull it away from the wall. This helped break the silicone holding the tray to the wall, and probably also helped with the few remaining blobs on the floor which were still holding on tight.
So, the boss of the new plumbing firm I've gone with came round this morning to take a look at things. (Tiling has now been postponed to give them time to clear up the mess created by the first plumber). He wasn't happy about sink/bath/basin all going into one waste and has recommended running 3 new wastes into the soil pipe. These will have to dropped down to just below the ceiling in the lounge and be boxed in, as drilling even more holes through joists is definitely not an option.
He has also recommended cutting out the shower pipes to allow for copper elbows to come out of the wall, as currently the bit of copper coming out of the wall goes straight into a plastic pipe and the two pipes aren't even level!
Agree with him but you can combine the shower and basin in 11/2 as it's very unlikely your going to be running the basin taps when someone's having a shower even then it would be fine
On that basis, couldn't the bath waste also be combined with the shower and basin wastes, since it's extremely unlikely that we'd be emptying the bath whilst having a shower? Anyway, I got the impression the primary reason for separate wastes is to avoid water in one waste getting sucked out by another appliance's draining.
You would have to up the waste to 2" pipe but you could and stick an anti vac trap on the basin
Ah, I see, ok... so maybe just as easy to run 2 separate wastes? The one from the bath can go straight to the soil pipe. The shower and basin wastes will now have to drop below the joists and run tight along the lounge ceiling and be boxed in.
Yea or run the lot in 2" and box it in and strengthen the joists
Reply to the thread, titled "OK for waste to run uphill a short distance?" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
UK
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
waste
trf0412,
trf0412,
