Have they been pressure tested?
I would do this first before going through everything else then finding leaks.
These rads are not designed to work at 3 bar pressure which is the safety valve setting on your combi.
They have spent there lives so far in open vented systems with a head pressure of a floor or two i.e. 0.6 - 1bar.
If I were you I would be testing them first as SimonG suggested, then I would fit a safety valve with a lower setting to the system!
BTW - TBOE for the con's
Hi everyone,
need a bit of help again please with a couple of problems
So we had x20 radiators and we managed to get the cap-end/ valves off x18 of them to swop and do the bottom-bottom flow/ return.
Then problem 1 developed 🙁 Unfortunately- we managed to shear the valves clear of the remaining 2 using our big trusty steel pipe :S and the thread is now stuck inside. We have tried gently sawing to try and loosen/ hitting with a chisel and drilling but they won't budge. Does anyone know how to get these out other than praying for a miracle! We were going to try a steel merchant/ welder and see if they can drill them out?
Problem 2 is some of the fittings are in pretty rubbish condition so I don't know whether to get new. For some radiators its 1.5" opening and others its 1" so I was going to get these reducing bushes to fit our 15mm valves and put new stop ends on-are these the right type?
Also been advised to use LSX sealant when fitting the stop ends-is this the best one do you think?
Thanks-any advice much appreciated 🙂
Elli
Fittings
JTM Brass flanged plug-threaded brass
1"
1.5"
JTM Brass hexagonal bush
1.5" to 0.5"
1" to 0.5"
so kind of like use the hacksaw to notch the thread that's stuck in then try and sprise it out?
on the JTM website if its described as galvanised is this steel? Are these more hard wearing?
thanks
When the 10 to 12 piece is removed. I would hammer 1 towards 7 or 9 towards 3 which ever gave the most bite.
Hi everyone, been advised to use LSX sealant when fitting the stop ends-is this the best one do you think?
pressure wont be a problem ive had cast rads with 8 floors on them all the big buildings in london originally had cast iron rads
