Old waste pipe size help
View the thread, titled "Old waste pipe size help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting.
The fittings at floor level so I’d be looking to bend (90 degrees) straight away so I can get the lowest possible shower tray.
Could someone advise what I could use you as 50mm pipe is from the standard screwfix is too big.
Any help would be greatly appreciated.
Reply to the thread, titled "Old waste pipe size help" which is posted in UK Plumbers Forums on Plumbers Forums.
Marky22,
ShaunCorbs,
