bezford
Hello there,im new to this forum so i hope im doing things right..ok,well....my mams a pensioner and she has a slightly dated bathroom suite but cant afford to fit a new one so i need to fix this for her and i hope you guys can help?
The main problem is with the toilet the flushing is now almost not do-able by my mam as it takes a strong arm to do it so i usualy do it when i can but the fault is that it fills the cistern ok then when i go to flush it i have to grip the handle and in fast pumps i have to force flush the handle up then down then up then down several times really fast then i hold it down after about 6 or 7 pumps,until the water is changed and the flush is done and finished.
Then next time it requires the full pumping action again which my mam really struggles with.So if anyone knows of a remedy please let us know as soon as possible so we can get it sorted....thankyou guys..
The toilet is around 15 years old,with porcelain outer and plastic parts inside,i think it is syphon fed with the flush handle at the top right corner as you look towards the loo,unfortunately i have no pics but i might be able to take some if vitaly needed...thanks again.Rob Hyde...
