Phew, thought I'd upset you without realising 🙂
So in essence you're saying you'd be quite happy to go leave your home with the pilot lit on your fire with no safety device? What if it blows out, the room fills with gas (The explosive limit of NG is 5-15%) and you return when it's dark, open the door and switch the light on and get a spark? If I was in the engineers situation, I would have requested your permission to cap off the fire and issue an 'At risk' notice. If permission was refused, it would be noted on the service record which you would be requested to read and sign.
replying with caps cos i didn't realise i put capped off when i should have put turned off. Not offended at all, thanks for pointing it out.
Can I say 'bolloks' on this forum without being excluded?
well done so!
Permanent pilots are inefficient and that is all they will ever be! You will never be able to blow up a house, flat or otherwise unless it was devout of ventilation!
Well maybe a Wendy house! ............ REALLY SMALL ONE!
seen the news earlier. in america they are raving about shale gas, the clip says it is getting into the water supply and it showed people lighting the water as it came out the tap, looked excellant
most gas fitters under the age of forty havent seen many appliances with pilots so it an understandable mistake which they should put right as to pilots being dangerous we used to have several standing pilots in our old kitchen the one on the grill saved us having to put the light on at night
oh what fun we would have when the shilling run out especialy getting the fridge one to light had to put a plate with hole in over the flue and wait till gas filled the flue tube then put a match to it
its only ncs, ar or id is a different matterLOL showing some age there mate. Never seen a gas fridge...
Would scrap the fire and buy a new one. Of if you cant afford it right now i would remove/cap off and wait. I know it was ok when installed but too easy for somthing to happen if ask me.
ive still got a standing pilot on my vailant boiler no problems except outage in the wind
Thanks to everyone for the advice.
The firm is still flatly refusing to re-attend and reconnect the fire so I've had to register a complaint with Gas Safe.
Does anyone know what powers Gas Safe has or could I end up having to go to court ?
