Feb 23, 2009
69
Coventry, West Midlands, England
DIY or Homeowner
I am in the process of redoing my bathroom (in fact I have been for a long time now!) and I will shortly be installing my bath and shower cubicle.
The pipework to the facilities is in plastic. My bath is going to have a bath filler (Centrafill from Screwfix) with wall valves. The instructions are very limited and make no reference on how to install the wall valves. There is no mounting plate for them. What is the most ideal way to mount these in a partition wall. I presume I am going to have to connect the plastic to copper at some point. Is compression or push fit the most secure way of doing this? I was then thinking of adding some wood frame work and securing the pipes via clips to this and then attaching the valves. The back of the valves have no mounting points at all. Is this usual?
Equally I will be installing a Mira minilux mixer shower. This is not the standard bar mixer but a unique design so I can't use one of the mounting brackets available for bar showers. Has anyone any suggestions on the best way of mounting this in a partition wall also? It does state in the manual that it would need to be copper so once again I'd have to join plastic to copper.
Any advice would be gratefully received plus if anyone has any links to photos of a similar job that would be good too.
Thanks in advance,
Daz
Bit tricky "advising" or suggesting without seeing the bits and bobs and walls, space etc.
If you have a camera on your mobile, why not take a few holiday snaps then pop down to your local plumbing merchant. They're usually very helpful with things like this.
Agree, impossible to say without seeing the bits. Your local trade counter plumbers merchant is a good start. One thing for sure though if you intend to make the pipework a structural part of the strength of the finished fitment then do not use anything other than fully soldered joints. Compression fittings, brass or plastic should not be stressed in service. When it comes to joining the plastic to the copper I have to say that having seen many burst and pushed apart compression joints due to freezing these last few weeks I am amazed how J G Speedfit joints and plastic in general survives ice. Changed my view of plastic a bit to be honest; still wouldn't have it in my house though.
