plumbfix magnetic filters
View the thread, titled "plumbfix magnetic filters" which is posted in UK Plumbers Forums on UK Plumbers Forums.
L
lame plumber
ae235
Anyone tried one yet £52.50 plus vat fm plumbfix, cant be worse than some outthere, 5 yr warranty
I got the email from em yesterday and thought this was a bargain.....but.......will be a while before seeing any feedback.
I think I'll stick to the king of filters, Trappex, for the moment. If it was possible to produce a decent magnetic filter at that price I'm sure some of the other big boys would be doing it.
they are producing them at a price, but charging them out for a LOT MORE!
A SALUS filter in disguise !
ask yourself this
(1) can you service this filter without disassembly NO
(2) does this have a flow management system NO
(3) does this capture non magnetic debris NO
(4) magnet in direct contact with hot water ,possible magnetic failure
(5) does the isolating valve detach from the body incase of ISOLATING VALVE failure thus having to buy the whole body similar to the fernox tf1 NO
(6) O ring failure in the lid section similar to magnaclean YES
(7) are they made in the UK Yes (Moderated by Dan after the brand contacted us to show it in fact does say on their website that it is).
(8) does this filter have a dosing point for inhibitor NO
Added by Dan 15th Aug.
  • Why wouldn't you want to see whats happening inside? Using a 'blow down' process to clear the filter only dilutes the inhibitor concentration
  • From our experimentation when developing the product, flow management results in blockage. Free flow around a powerful multi element magnet works better for us
  • The unit contains a non-magnetic dirt trap
  • Our magnets are nickel plated then sealed in a stainless steel sleeve so are fully protected against exposure to water
  • The isolating valve is bonded to help us achieve a 10bar at 82C pressure rating, independently tested by WRAS who advised a safety margin of 3 x the pressure it would likely see
  • Our lid is 2 part so the 'O' ring is clamped and not twisted as was implied. Again its pressure rated to 10bar at 82C
  • You have dealt with 7 – thank you
  • With the lid off the filter IS a dosing point for liquid chemicals. The bottom valve allows the unit to be fully emptied before adding these chemicals
cant comment on trapex as not used one, got an answer on the plumbfix one, good warranty on it though, bit like ferrollis🙂
bought one today when in plumbfix but def pulling bloody awful no nonsense sticker off thought id try it for a 5 year guarantee. i'm sure centramags are fine but no where near me selling that i know and not at that price.
LMAO i've fitted a quite a lot of the ferroli modena he's 4 moving parts stainless steel heat exchanger theres a lot to like about the boiler 5 year part and labour warranty.
buy a axe
no need, over on this side of the channel we've learnt to use a new tool, the s-c-r-e-w-d-r-i-v-e-r, it makes servicing a lot easier nowadays, Im sure we can send one to Wales for u to try, I'm sure they started to use them when Rovers were being built, 🙂🙂🙂
what you have just discovered screwdrivers?and ferrolis?? gosh you must be at the height of technological advancement down there in devon
no can do my good man.
yep previous ferroli's are awful but then all manufacturers have had bad boilers .look at the isar but plenty installers on here now installing the logic.
Just had a quick gander on their website, looks pretty good to me actually, intergas style thinking.
If it wasn't for diverter valves though most of us would be out of work.
too true, we even have intergas boilers now, havent seen a rover for ages, except in the Haines motoring museum 🙂🙂🙂
I like the fact all these new boiler have long warrantees, as long as we service them annually🙂🙂🙂🙂
Question where do you get all your info from? because reading the above I can assure you the Plumbfix is made in the UK!
Yes that is what it states but a salus rep that i know tells me all the salus products including the filter is made in there chinese factory ,it also states dosing point for chemicals but it does not have one .
Hold a Centramag in your hand and hold a plumbfix no nonsense filter(salus) and you can tell the quality of the plumbfix filter(salus) is made in china .
Plumbfix is made by Lettergold according to the Adey rep I saw today boys.... Not Salus
From the looks of "Dizzy's" two posts Id say they are from either Lettergold or Plumbfix!
the only people who like ferroli's are the people who charge the customer a fortune to install then 😉
Although I do quite like the Modena, simple boiler, easy to work on/find faults, probably the best they've made, but then not familiar with the HE version. All the other condensing boilers they made have been absolutely terrible!
oh the innocence of youth, I love ferrollis they keep me busy servicing, repairing and replacing at HUGE cost
look at the salus filter and the plumbfix filter exactly the same
I'd say that Salus are also buying their filter from Lettergold then mate, do a bit of googling and you can find Lettergold buying an injection moulding machine news pr, might be some joy in approaching salus to sell yours?
i must say i went to plumbfix to look at this filter and it is a absolutely poor quality product ,flimsy spanner ,no street elbow provided .Rang one our merchant customers and had a conversation about the salus filter and he refused to put such a poor product on his shelf!!!!!
I have a sample Salus filter on my desk.
Without disrespect to Bspareltd, I don't think its as bad as that. It looks ok to me. My view was that it wasn't cheap enough to compete at the budget end, and it didn't offer any benefits to compete with the established brands like TF1 or Magnaclean at the top end.
The price range of filters is relatively narrow, so I am not convinced that there is room for a "mid market" product - I think most customers will either buy on brand name, habit or price. Rightly or wrongly, Salus is firmly associated with the budget end, and this product simply isn't cheap enough to hack it there.
yes you are right the salus does fit in the budget end ,but what puzzles me they are stating it catches non-magnetic debris and it has a dosing port both untrue.
Is a decent street elbow and a decent spanner really a selling point on a magnetic filter though?
I personally have never used the street elbows provided with the magnaclean as they are cheap thin copper and when I service am filter I never use the provided spanners. Most customers don't know where they are anyway 🙂
surely the main thing that counts is how much mick it collects and how often it leaks, based on this, my filter of choice would be the spirotech magnabooster. I've seen to many tf1 filters and magnacleans leak to favour those.
I haven't seen any other filters in action so can't really comment on those.
Reply to the thread, titled "plumbfix magnetic filters" which is posted in UK Plumbers Forums on Plumbers Forums.
lame plumber,
bspareltd,
