Plumbing help in kitchen needed - can't turn water back on!
View the thread, titled "Plumbing help in kitchen needed - can't turn water back on!" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi there,
I've recently done the plumbing in my newly renovated bathroom and thought I'd have a go at the renovated kitchen. All was going well until I managed to move a 15mm cold water pipe and cause the stopcock to drip! I managed to stop the drip but am nervous about continuing to experiment! If I mess up the stopcock I'm seriously messed up. I really didn't want to call a plumber in if possible as I'm trying to learn from my mistakes
So, my gas man had encouraged me to use quick fit plumbing fittings and I wanted to simply add a 15mm equal tee to the cold water line for my new dishwasher. I bought the Speedfit part and when I tried to fit it...things went downhill.
i carefully measured where to cut the pipe and tried to get both ends onto the pipe and then screw it back together...but without success.
I'm sure I've made a massive mess...and I now have no water because I can't put it back together!
Please see the attached photo and advise if you can.
Thanks a lot,
Taryn
(I thought about adding a few elbows which could work but would be completely bizarre and messy I'm sure).
First I hope you used a pipe slice to cut the tube as a hacksaw will leave a ragged edge which could damage the O ring seal in the push fit coupling. As you have found out, in order to connect the coupling the pipes have to be moved apart then brought back together again. If you have an adjustable spanner, close the jaws so it just fits the 15mm pipe, place it behind the white fitting on the left and push fitting off end of pipe. Provided your pressure is on the inner collar at the back it will remove O ring and grab ring at the same time. Pressure on the wide part of the fitting will just make grab ring grip harder. Once removed reassemble and try again.
That's almost done...I just have a couple of fittings from my shower valve that are leaking very slowly. I can't seem to get the right amount of PTFE tape...(I think that's the issue) Sorry...can't get photo turned round.
Find your stopcock out in the street or if you live in a flat it will be in the lobby maybe. Make sure it turns off the supply to your property. Then if you get a leak inside or break something, you can turn it off and repair at your leisure.
So interesting....I'm a recent convert to the joys of plumbing and am trying to learn all I can. That makes sense with compression fittings as I wondered why most of them didn't have tape. Can you use too much tape? It seems that sometimes I have put too much and it doesn't screw in that much. If it doesn't leak I guess that's okay! Also, is it standard practice to tape the olive rather than the screw bit? Thanks!
Reply to the thread, titled "Plumbing help in kitchen needed - can't turn water back on!" which is posted in Bathroom Advice on Plumbers Forums.
Taryn Hauritz,
village idiot,
