C
Chrisgy
Got a boiler to fit tomorrow. The flue will be 150mm from openable window, so the surveyor has said to fit a plume kit to take it away from window. Is this allowed? It's a Worcester going in
This is ringing bells with me, I think that it allows the flue tobe 150mm closer DO NOT QUOTE ME ON THAT though, I see if I can find a link.someone posted a link on here to a worcester mi not so long ago saying you can do this
why ,thought that is what a plume kit was for ,to take fumes away from places like conservatorys with openable windows otherwise what they for ?
flue can come out of the wall and be less then 300mm to window,they and vailant allow it cos i have spoken to there tech services !!
you HAVE TO USE PLUME KIT TAKE PRODUCT OF COMBUSTION AWAY ! and it all make sense to you ones you open your boiler and have look on that separate book for FLUE TERMINALS that comes with it!
though you as gsr will know this !!!
Say the MI's state min. 300mm from opening window. You cannot install a boiler with its flue fitted 150mm from opening window and then stick on a plume kit to attempt to bring it into line with the MI's. The boiler with its standard flue is installed not to MI's."It cannot be used to make an illegally fitted flue become compliant with the regs/MI's"
how do you mean ?
can you explain ,pls!
off the top of my head I am sure worcester say if a plaume management kit is usedthen distance from openable window can be reduced to 150mm
I would need to see this in writing then.i agree with the above...it is allowed.
Reply to the thread, titled "Plume kit to move from a window?" which is posted in UK Plumbers Forums on Plumbers Forums.
