recently I've had 2 customers mention similar faults with their potterton suprimas
both said that the hot water doesnt come on some mornings for some reason and the boiler needs to be reset before it will go back to functioning normally
the problem is it only happens intermittently and neither time was i able to recreate the fault, this obviously makes it hard to fault find.
Both customers were unable to remember the flashing sequence on the boiler, but when asked was it flashing red (ie locked out) thought that it could have been
what i couldnt understand is why is it only happening occasionally, is it an overheat stat, or a PCB problem, where do you start if you cant see the fault
