View the thread, titled "Powerflued gas fire" which is posted in Gas Engineers Forum on UK Plumbers Forums.
J
jgmgasservices
Hi went to a gazco room sealed gas fire. Looks like a standard stove flue goes into chimney breast then rises about 2.5m 90deg to a ceiling void (with a hatch). Selkirk twin wall by this point another 90deg outside to a power flue fan unit. all taped together.
It just doesn't seem right
Switch on wall to start fan and let gas to fire, when switched off fan off gas cuts off.
No instructions. No model number
Is the flue in the chimney breast classed as a flue in a void?
I have capped for now gonna speak to manafacs.
Cheers
So the stove is balanced flue not conventional? If so then you were correct to condemn as fan unit can only be fitted to a conventional stove
it is room sealed and has a fan, the fan is on the externall wall.
Never come across this before.
How's it getting fresh air if it's balanced flue? As the fan unit would cover both air intake and exhaust. Sounds like a bodge job
I think you will find it is one they powerflue fires and it is actually taking air from room and fan is drawing POC's out back.
But the taped up flue may need a look.
Pictures tell a thousand words!
It should be one of these
[DLMURL]http://www.stovax.nl/idoc.ashx?docid=906e11fe-4e5b-4ef7-9330-39010eafddb5&version=-1[/DLMURL]
Thanks. Got my head around it now. The power flue is installed correct with the gas shut off etc
Just i was convinced the fire was room sealed. Going back next week to take a look, if the fire is not room sealed then all good.
Will let you all know.
ta
Reply to the thread, titled "Powerflued gas fire" which is posted in Gas Engineers Forum on Electricians Forums.
