Problem with cracked pipe from bathroom to outside tap.
View the thread, titled "Problem with cracked pipe from bathroom to outside tap." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, the property I live in appears to have had a pipe to an outside tap run from the cold water pipe under the bathroom sink. Yesterday the outside pipe cracked where the tap connected to it and water was gushing out! For the life of me I cannot work out how to stop the flow of water. The isolation value on the cold water pipe under the sink works to stop the sink tap working but has no effect on the flow of water into the pipe running outside. I've taken off the bath panel and all I see is the hose attaching to a pipe and no isolation valves. Am I missing something really obvious or has this been completely bodged by whoever installed the tap?
The slot should be inline with the pipe for on and not inline / 1/4 turn for off
Thank you, I have got this perfectly aligned now , can't hear any water noise in the pipes and stopped the flow of water into the garden. Hopefully this continues to work until I can get a plumber out. Not quite sure how it will work pipe wise once the hose is removed (and don't fancy flooding the bathroom to have a look 😂)
Reply to the thread, titled "Problem with cracked pipe from bathroom to outside tap." which is posted in UK Plumbers Forums on Plumbers Forums.
ocxomel,
ocxomel,
