Problem with Kane 458s
View the thread, titled "Problem with Kane 458s" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Issues with Kane 458s
Bought unit back end of April 2022.
1st. Problem sent back to Kane on 7th July. After flue sampling it would take 2 minutes to slowly drop coppm. Then hang at 4 coppm for next to 3 to 4 minute's before zeroing in fresh air. Also ratio would jump around.
Kane fitted a new CO sensor.
2nd. Problem sent back to kane on 6/12/2022. On older pre-condensing boilers I'm getting unbelievable clean ratios of.
Example given:
Ideal Mexico rs 80
Co2 7.9%
Coppm 10
Ratio 0.00001
Baxi solo 2 60pf
Co2 6.7%
Coppm 5
Ratio 0.0000
These are both fixed rate burners which I would expect ratios of between 0.0006 to 0.0030. Both are pre-condensing boilers.
I'm beginning to lose confidence with this analyser. My previous 455 I had no issues with.
Kane has had the analyser back for service now for 6 days. I phoned kane today and somebody was supposed to ring back but know one has.
Has anybody had the same issues
I'm struggling with mine too.
I've noticed a couple of readings seemed off but didn't question it.
I got it to replace prev model and assumed it would be just upgraded hardware but soon found its completely different.
Firstly there is no light and don't have control over backlight.
Pressure range is much lower, on last FGA I could test over 100mb but not now.
Can't turn on manometer without full purge.
Test results are not selectable like before so storage of results is mostly pointless.
Dropped it from about 1ft and now airpump not working.
Going to get old one serviced and get rid of 455 when fixed
Mine the same. Analyser purges even when turned on for pressure testing.
My old 455 you could turn on in Manmode which didn't run the pump on.
Update.
Got an email from Kane on 13/12/2022 with PDF service certificate and calibration certificate saying everything passed.Also got a text that it had been posted back on 14th.
Emailed kane today 20th to find out why it hadn't arrived in post yet. Only to find out it still hadn't been posted.
Also got another email with a service pdf document with today's date 20/12/2022 saying CO sensor failed. This is strange that the service document I received on 13th said everything had passed.
So with postal strikes its been 3 weeks without an analyser.
Not happy
Oh I'm glad you think the same, I literally rang them up last week and rhymed off the same list to them and told them the new 458 is c***
Got various issues with my new 458.
The main one being the CO2 is under reading, I recking by about 1%. Given up trusting it at the minute.
It takes forever to read to, the old 455 would instantly read within 30 seconds. This takes up to 3 minutes to level off. Same when doing pressure tests, it takes ages to give you the correct pressure reading.
Comes inside every night, into a heated garage at 21oc. Can't ask much more than that.
Was going to try and get it back to them over Christmas.
Be prepared for a long wait. So much for Kane Care.
On speaking to service centre It's 1 day turn around on calibration but 7 days on service and warranty work. Although they received my unit on 6/12/2022 and I'm still waiting. Must be overwhelmed with failed Kane 458s units 🤣
I believe it’s Because they don’t make that unit themselves I believe it’s a USA brand
I did exactly the same 🤣.
It's a shame. I don't know what's going on internally but feels like the beginning of the end for them.
Worst analyser ever. I bought one in Aug 22 and Kane have had it more than I have. I won't ever buy one again.
I didn't get my analyser back until the 23/12/2022. Took them over two weeks to try and sort out issue.
Even now it still takes 3 ½ minutes in fresh air after flue sampling to zero coppm.
They had mine back. Was reading about 1% out. They said nothing wrong with it. Still isn't right. Had a 455 reading 11.1% and my 458 reading 9.8% CO2. Joke.
I know it’s not in everyone’s budget, but I’ve never had an issue with Testo.
I do commercial and oil, so need reliable kit that can take a few high readings without having a heart attack.
No surprise. 458s packed up again this evening. CO2 was playing up, then it went mad showing a CO2 reading of 16% now it won't read a thing!
They replaced the CO2 sensor back in June on the calibration after me complaining about it being faulty - it had been fine up to now. Still be bringing it in every evening - whether they don't like to cold being sat in the van all day however you've got to use them somehow!
Mine needs to go back for calibration by the 20th December. It still takes 5mins for Coppm to zero in fresh air. Drops to 4ppm then takes 5 mins to then go to zero. Also takes ages for Coppm reading climb to its maximum level when sampling. I think kane should offer you a heated blanket to rap it in. 😆
Thought I would just update with another Issue with my trusty old Kane 458s. Today whilst Analyzing a Worcester Bosch 24ri I couldn't get the Co2% to adjust without the ratio & Coppm going to very high levels. Then found where the rubber hose goes into the rear of the probe handle, it has either come adrift or broken. Lucky I still had my old Kane 455 probe and hose and had to go home and get it and swap it over. I found the issue by blocking the Probe tip and blowing down the other end and air just Sodes out of the probe handle. The probe & hose have not been abused and look as good new. I've contacted Kane tonight through Kane Care website. Hopefully will get a new one sent out.
Just a helpful warning to other Kane users to check probe before condemning the boiler.
Reply to the thread, titled "Problem with Kane 458s" which is posted in Gas Engineers Forum on Plumbers Forums.
Kevin M,
Kevin M,
