F
fishhead
Hi all,
Please can i have some expert advice. I have a gravity fed system and i've just bought a lovely mira digital low pressure shower system that comes with a pump specifically for gravity fed systems. This pump will just provide pumped water to the shower.
As i'm also in the process of re-modelling my bathroom i'd like some new bath valves/taps and a bath waste filler. All the ones are like are not compatible with low pressure systems so i'd like to buy a separate pump to feed the bath and sink.
How do i configure the pipe work so that i can have 2 pumps without either one affecting the other?
i'm happy to run a separate cold feed from the tank in the loft to the shower pump but what about the hot?
do i need to use non return valves and if so where?
I hope this is clear. Any help or steer would be greatly received.
Thank you
Fishhead:
Why, if you are refurbing the bathroom, are you using taps that aren't suited to low pressure and then fitting a pump? Would it not make more sense to use taps that ARE suited to what you have?
Ric2013. All the taps I like only seem to be compatible with high pressure systems (not gravity fed) so if I put a pump in this will give the high pressure I need - will it? Surely a pump is the best way to go? I'm very open to advice as I'm a novice. Thank you
Personally I would keep looking for taps, not sure the noise of a pump will be to your liking.
PS. I am sick to death of the sound of mine.
