Ric2013
3,925
113
Colchester, Essex
General Plumber
Feel free to mock me for my lack of knowledge, but if you can provide any advice whatsoever, it would be most appreciated as I want to learn which is why I'm asking these questions!
When laying a waste pipe in concrete ground floor as a retrofit (for e.g. a shower tray), I can see see potential for problems, mostly related to the damp proof membrane getting damaged.
As an example, when rectifying a lack of ventilation to a part of my ground floor at my home (known as "Bodge Central"), I discovered that in the porch, the DPM was between the 2" screed and the concrete below. But in my lounge extension, it was below the concrete base (no sand between the plastic and concrete), but someone thought two bits of thin plastic were as good as a single thick sheet so the DPM was easily damaged. In the end I took a road breaker to the lounge floor and put in suspended timber.
When trying to keep a job contained, such as in a customer's house, how would you go about this? Obviously you'd only need to remove the screed plus a proportion of the concrete to get sufficient clearance for a 40mm waste (wrapped in felt?) plus any required fall... I think.
I'd imagine a Kango rather than a road breaker so as to chip up only what is required using a grinder to help if need be, lay the pipe to an even gradient, wrap it in something to allow expansion?, allow for access, pressure test, and backfill with a weak mix.
If the DPM turns out to be just below the screed though... but perhaps that only happens in very amateur situations where building control is not involved?
I'm a bit lost, and I'd like to know what people consider the right way as I see too much of this sort of thing done wrong.
There are lots of acceptable ways to construct a floor. BR Part C Section 4:
https://www.gov.uk/government/uploa...achment_data/file/431943/BR_PDF_AD_C_2013.pdf
The problem with making modifications to existing floors is always how to make reliable bonds between the old and the new. My advice would be to Google 'concrete repair contractor' and get a company that knows what they are doing quote for the concrete work.
I see your point. There are 9 and 50 ways of doing it. Trouble is I'd be showing someone a bathroom currently in use and saying 'how much to make a channel between here and that wall and let me put a pipe in it up to a SVP I can't currently see due to a false wall concealing services' and they'd probably laugh at me.
You are right though. It's all wrong in this country. We have builders doing bathrooms and fitting the plumbing (badly). Then they undercharge and can't afford to pay a plumber to do the plumbing work how it needs to be done.
On the reverse side, we have plumbers doing bathrooms and that isn't, strictly speaking, mostly plumbing work either. I tried googling as you suggested and all I can find around here are people who lay drives, erect fences, and supply readymix.
Though I think I'm about to hang up my pipe bender once and for all as, now I'm being offered the bigger jobs here, I'm being told that I cannot use the local tip even as a paid-for service, there are no places I can take waste in less than 1-ton increments (at £108 a ton which would seem a bargain if I had more than a car-derived van and zero storage at home) and the council will only collect bulky business waste from my house if I have a wheeled bin (in effect a skip) kept on site
Looks like I'd make more money clearing out the tool storage room and getting a lodger then working as a labourer part time with no responsibility! Or sell the house and get the ---- out of Colchester.
Yes, just weird when all you're doing is replacing a bath and you need to spend more on disposing the old one than the cost of the new one. More concerned about the concrete floor on another job
I've had my waste rant... though there's a council meeting on Wednesday I may attend...
