How's best to fit them on plasterboard walls? No studs found. Underneath a window. Double panel. 1600 x 300
Setting tool?
What does the setting tool do and how do you use it?
What's the heaviest weight these can handle?
So, there are various sizes.. I'm assuming its width x length???
http://www.toolstation.com/shop/Scr...d1930/Fischer+HM-S+Metal+Cavity+Fixing/p73656
Am I right in thinking the longer it is, the more load it can handle???
They are rated to about 20kg per fixing on average.What's the heaviest weight these can handle?
I like the wall fixing in the above links and find them strong enough for small to medium rads. I like that they stay in the wall if you remove the bolt.
But also consider these, expensive but very strong and will also stay in the plasterboard, -
https://www.edwardes.co.uk/en/categories/thorsman-platti-plugs
These look quite good!
cut the plasterboard out behind where the brackets are, so cut out 2 bits with a padsaw, say 250 long (300mm rad) by 100mm wide. now cut 2 bits of 18mm ply, 250mm long by 200mm wide. Slide the ply into the hole in the wall at an angle (be careful not to drop it inside the wall, you need to put a screw in the middle of the ply with the head sticking out to give yourself something to hold onto)
Now the ply is behind the wall, centre it up in the hole so it overlaps each side evenly 50mm then screw though the edges (25mm in) of the left and right side of the plasterboard and into the ply which will pinch it all together. Now replace the PB you cut out earlier and screw it into the ply.
the "twirly" type ones are good for 15/22 pipe clips, that's about it.
Isn't this essentially weakening that section of plasterboard though, because you've cut a hole?
There **** jay won't hold anything that high of a kg rating
Think I'll do the ply thing then.. Certainly don't want them falling off the walls!!!
You will be fine with them ones we linked unless they want to sit on the rad
Ok, I'll give the Fischer ones a go - cheers Shaun
sorry jay linked the wrong vid
[video=youtube;7mpcer0QzW8]https://www.youtube.com/watch?v=7mpcer0QzW8[/video]
So these hollow wall anchors, anyone used them for boilers on plasterboard walls?
Hopefully not!
I've only had one pb wall and used a bit of ply the size of the boiler in between - but just thought I'd they're good enough for a 50 kilo rad...?
Mounted on ply ..what happened to not fixing to flamable material..or was you sleeping during that part of ya gas safe refresher..good to see gas in safe hands
Turned out that hollow wall was a solid wall with half inch of plaster on it - sounded hollow to me! Lol both rads (1800-600 & 1600-600) fitted and well.. Cheers guys
If you were gas safe you would know the rules have changed
Some manufacturers instructions over rule this but were in the general regs has this changed...think you should recheck toooooo...
Which manufactures do then ideal, vaillant, Worcester, Viessmann, atag all accept new rules
Look
Didn't quite work like that...we have general regs that manufactures with there own products can over rule and set their own prescience ...all you have to do is tell me were in the standard regs that it says you can now fit a boiler to a flammable surface...simples...
Ive never used no setting tool with these...just tighten them up undo the screw and fix whatever your fixing ...done thousands never had a problem yet.
I find that a bit slow if using a hand screwdriver tbh. But if you do just hand screw them tight, one tip I found is put a dot of oil below the head of the bolt, because there is massive friction between the head and rad bracket (or whatever) while the bolt is pulling the toggle legs tight.
The setting tool is just one squeeze and it's done and without risk of spinning the toggle in wall.
Have you seen the new blade fixings
Worth a google
