The times above are in minutes, so it's off for ~3 minutes or so before starting up again.Not sure how long it rests before starting up but it’s in the boiler program.
Presumably the deltaT figure which you refer to is data which a radiator manufacturer can easily provide if I were to ask for this figure from a different manufacturer before purchase (and hoping that the figure which they provide isn't an over optimistic figure). What sort of figure would I be looking for, ideally?the output of that rad as its measured deltaT was only 4C.
Do you think this poor modulation issue is related to the radiator/balancing, or would it be specifically an issue with the boiler?Also the shockingly poor modulation means that a min 8 kw heating demand must be maintained to allow the boiler to run continuously.
Slowing flow through this radiator will drop its average temperature by 10 degrees or so, 40 degrees hotter than the 11 deg room instead of 50 deg so 20% less heat emission but for 100% more time. If a more continuous flow is delivered through it it will emit more heat overall. OP obviously wants a new radiator but he’ll be disappointed and poorer. He’s certainly not listening to me.Seems to be a consistent 3 mins off time, certainly agree with new window but all the balancing in the world IMO will not improve the output of that rad as its measured deltaT was only 4C.
I don't want to appear that I'm not listening. Ultimately, I have no plumbing background. I'm listening to two different opinions here and, yes I can get the window sorted, but aside from that I don't know if I need a different brand of radiator or if it's just a matter of getting the system balanced or if there's a problem with the boiler? There are no boiler error messages on-screen.He’s certainly not listening to me.
If it helps you, I pretty much agree with John.g.I don't want to appear that I'm not listening. Ultimately, I have no plumbing background. I'm listening to two different opinions here and, yes I can get the window sorted, but aside from that I don't know if I need a different brand of radiator or if it's just a matter of getting the system balanced or if there's a problem with the boiler? There are no boiler error messages on-screen.
If your whole system was balanced so each radiator had a 15deg drop you might surprisingly be able to increase boiler flow temp yet lower return temp so increasing overall efficiency.
Thanks guys, your input is very appreciated. As I mentioned earlier the flow for this rad is definitely going into the lockshield, and ideally it should be going into the TRV (which is not bi-directional). So I'll get that sorted and then I'll get the rads balanced so they have 15 C drops.Balancing will cost you nothing, there’s a thread here on how to do it.
Thanks for mentioning the diverters, as I hadn't heard of those. TBOE (the best of everything?)IMHO, all these rads should have a diverter fitted or be plumbed TBOE.
I've just seen a picture of TBOE at the link below, and yes that is ugly.IF you put TBOE (top & bottom opposite ends)in the search box you will find a lot of info, its supposed to be the best way to plump a rad and it might but its certainly the ugliest.
I'm doing that ASAP.This will work fine if you plumb it correctly ie flow into your uni-directional trv.
Re-plumb this rad and balance your system - the report back.
For what it's worth, I've asked the radiator manufacturer and they state that the rad does not require a diverter (or have an in-built one).Would agree with above re different type of rad as there are numerous posts re the (non) performance of "tall" rads, IMHO, all these rads should have a diverter fitted or be plumbed TBOE.
It's 3 bars per column. It appeared to go up the central bar directly above the feed. Then go across the top directly across all at the top, then cascade down heating all at same time. Hopefully, that sounds ok, if not I can repeat and see if I can determine any further detail.So, is it first moving all along the bottom to the return (outlet) straight away and is this return hot first or as soon as the others start heating.
It was set to 60C though in reality it fluctuated up and down between, what was it, 55C and 67C ish as it cycledOne other query, when you took the cycling times tests with four rads and then one, what was the boiler set point temperature?.
