Replacement Kitchen Sink - Waste Alignment Question
View the thread, titled "Replacement Kitchen Sink - Waste Alignment Question" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I'm going to attempt to replace my sisters standard s/steel kitchen sink (inset/sits on edge of work surface hole type) for one that's as close a match as we can get. The only problem I foresee is aligning the new sinks waste trap with the existing waste pipe where it comes horizontally through the wall from behind sink cabinet.
When fitting a similar sink does the trap normally line up with the existing waste pipe where it comes through the wall? I assume I can solve any misalignment on the vertical plane with a telescopic trap, but what about horizontal misalignment - is it likely that I will need to re-drill the hole in wall for sideways alignment and fit new waste pipe through wall? Or, is there another way?
Thanks for any advice.
You may need to re do the waste/traps all together, you should not need to do a new hole just re do the waste pipe from the trap.
I would normally adjust the pipework to go to the original hole through a wall if possible if not yeah new hole and re pipe using solvent weld personally
Traps often are in 2 parts so they can swivel to adapt to being lined up with a waste slightly to one side. Or you could turn the trap 90 degree to the side and use a square bend on the waste pipe.
Never drill another hole through the wall if at possible. That's what 135 & 90 degree bends are for.
One more question; would a telescopic P trap give more chance of lining up to an existing horizontal waste pipe through wall than a bottle trap? Or is there little difference between the two?
Thanks for everyone's replies so far.
Telescopic traps are for height adjustment, to lower trap outlet to height needed.
Ordinary P traps that are 2 part, are adjustable by swivelling the 2 parts so to line up to a pipe that's not in line with centre of sink waste.
Standard Bottle traps don't do any of above.
Reply to the thread, titled "Replacement Kitchen Sink - Waste Alignment Question" which is posted in UK Plumbers Forums on Plumbers Forums.
plumbandplumber,
Best,
