I'm going to attempt to replace my sisters standard s/steel kitchen sink (inset/sits on edge of work surface hole type) for one that's as close a match as we can get. The only problem I foresee is aligning the new sinks waste trap with the existing waste pipe where it comes horizontally through the wall from behind sink cabinet.
When fitting a similar sink does the trap normally line up with the existing waste pipe where it comes through the wall? I assume I can solve any misalignment on the vertical plane with a telescopic trap, but what about horizontal misalignment - is it likely that I will need to re-drill the hole in wall for sideways alignment and fit new waste pipe through wall? Or, is there another way?
Thanks for any advice.
