May 30, 2022
South
DIY or Homeowner
Hi all,
Bit of a plumber novice that’s for sure, so apologies if my question is very basic or I haven’t made it too clear.
In essence, shower isn’t very warm, boiler and that is fine. Suggestion was thermostatic valve or mixer valve may need replacing. I have stripped the turners back along with the wall plate.
Looking at the bottom temp control it wasn’t quite as I thought, it appears to almost be one whole unit. Have attached a picture.
Hopefully someone can offer some advice around changing it for the correct replacement (wish I knew the make)
Thanks in advance.
