small boiler needed
View the thread, titled "small boiler needed" which is posted in Boiler Advice Forum on UK Plumbers Forums.
erj
Hi,, have been to look at ajob to night I need a gas system boiler 12 Kw to fitt in a kitchen cupboard 280mm deep, I have had a look at Baxi, Worcester but no luck can any one know of a boiler that is slim enough, thans inadvance
18kw flexicom system with rear flue. Or if satndard flue is suitable then ultracom 2 18 system.
You can range rate these down as well to your 12 kw.
Graham
Use a normal heat only boiler and then a external expansion vessel as it will save you the space to get it in a cupboard
Reply to the thread, titled "small boiler needed" which is posted in Boiler Advice Forum on Plumbers Forums.
erj,
Destroyer2813,
