works better if you open pipe somewhere else ie if you had a length of pipe capped 1 end, vacuuming the other end undo/take off cap to let air in
Don't the bleed valves on rads do the same thing?
The pipe can't be full of water but if there's a bit in turn your lamp on full pap and plenty of fluxI use mapp. But I've tried soldering with water in pipe and it doesn't solder well :/ how do you do it?
Thanks AW heating.. I'm having to cut quite close to the floor so I'm a little nervous about getting it wrong! But I'll take my time to make sure it goes ok 😉any method of removing the paint will be fine. If its not to close to finished surface then use a torch to help ther paint peel/ loosen. A scraper, pair of grips or whatever to remove the major amount of paint then a abrasive to clean the metal surface. Wipe the pipe clean with a damp cloth and solder as normal.
If the pipework is full of water then a wet vac is prob the easiest and cleanest method to remove that last bit of wata. For some reason these job always seem on cream carpet.
use the flux your comfortable with, if you want to try another flux do so on fittings that are easier to replace/ fix on a less important job.
