Stop frost stat kicking in?
View the thread, titled "Stop frost stat kicking in?" which is posted in Central Heating Forum on UK Plumbers Forums.
We have a 15 year old boiler situated in a poorly insulated garage (fixed to the same wall as our bedroom).
When it’s 5c outside (16c in house) it’s about the same in the garage and the frost stat kicks in. Twice a night we get the woken by the boiler coming on, the pump working and the pipes creaking.
Which of the following do you think would stop it coming on? I have £3k to solve the problem.
  1. Tube heater and insulation in garage
  2. Build insulated cabinet around boiler, frost stat and pipes
  3. Fit new boiler that is designed to be used in garages and has insulation built in (is that a thing?). New pump.
  4. Something else / combination of above
Put a new standard frost stat in with a pipe stat as well on the return pipe.
At the end of the day the frost stat is doing it's job. I'd insulate your garage more and maybe add a radiator.
Thanks @EvilDrPorkChop . Do you mean a regular radiator linked up to the central heating? Presumably this would heat up the room while the CH is on and then the residual heat would hopefully see us through the night? Is a tube heater a bad idea?
I would say answer depends on how you use your garage.
If it’s a workshop and you spend time there eg wood turning then I would insulate the garage and if that doesn’t do it , add a simple oil heater with a timer and thermostat. You could adjust this such that it kept the garage temperature above the point where your boiler kicked in on its frost stat.
My theory is that you may as well use the heat off the central heating to put a little into the garage, along with the fact that when the frost stat does kick in then it'll put some heat into the garage also to knock it off quicker, and help keep the boiler and pipes warm.
I think your best thing first would be to insulate though.
Is it a separate frost stat? If it is, is it mounted directly onto the brickwork? If it is then mount it on a block of wood off of the wall.
Reply to the thread, titled "Stop frost stat kicking in?" which is posted in Central Heating Forum on Plumbers Forums.
FrostStatTed,
FrostStatTed,
