Stuart Turner Pump Pulsing When Shower Off.
View the thread, titled "Stuart Turner Pump Pulsing When Shower Off." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
SimonG
Subscribed
Strange one.
Stuart Turner Showermate, supplied by customer, fitted March last year.
All was well until August when they contacted me to say there was an issue with it pulsing when the shower is off.
I don't believe in coincidence, but at the same time as the issue arose they were having an extension built and I had nothing to do with the plumbing.
Went and had a look, cleaned filters, checked everything out and could find nothing.
Phoned Stuart Turner who advised me to turn hot and cold feeds off at the pumps. It stopped pulsing and they said there's a leak on the system.
It's a good install, pump on floor of cylinder cupboard, hot water is first feed to pump and cold is directly from loft tank.
Customer advised me they were happy to turn it on and off at the switch.
Been back today for something else and they asked me to look at it again.
Chucked 2 new check valves on the feeds to the shower, checked the mini vessel charge as good but still pulsing when off.
Turned hot water feed off at pump and it stopped pulsing.
Only other hot water outlets in house are kitchen sink mixer and cloakroom basin mixer. I isolated both but still kept pulsing.
Anyone any ideas?
leave the hot outlet isolated for a while, then when you re-instate if it runs and you hear water flowing to make up what’s benn lost , you know there’s a leak on that bit of pipework.
Could building work have damaged a pipe?
Is it possible shower valve connections/pipe are leaking within wall?
I’ve just had one where ceiling got wet below and it turned out a female iron had split within the wall. ( this is because some clown had put about 40 wraps of ptfe onto the shower connector) - nothing visible until I started taking times off the wall.
Try taking the shower valve off and putting 3/4 brass caps on it, then liven up system.
It could be some sort of crossover? Although I know they should be equal pressure ( resistance will be different in hot/cold supplies)
We are at the straw clutching stage!
I'll give that a try.
Reply to the thread, titled "Stuart Turner Pump Pulsing When Shower Off." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
SimonG,
turnpin,
