swaps (combi to combi)
View the thread, titled "swaps (combi to combi)" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Normally getting around the £900 mark clear profit, sometimes a bit less sometimes a bit more
I take it you mean after your wage etc, that's a good profit fella, fair play
If everyone kept to the same pricing boundaries it would be great
Exactly that. You are always going to get someone to do it for £150 labour only, but then look at the lash up that the customer gets for that
I usually get upwards of £700 ish if it's a day job, but that's an easy install and not clear profit
Without a powerflush, only a mains and a chemical and a magnetic filter
Usually pipe up the boiler and get it running for a few hrs with the cleaner in it while finishing prv pipe, condense, rf stat etc
Just seen in the paper 995 combi to combi baxi duo 28 with power flush, that's what made me think
Mines coming out 1840 with Worcester atm
I would think that is literally a straight swap no gas/ condense run not altering pipe work at all so a 105 off the wall and duotec on.
From the book price at plumb they would make just short of £200 off that.
For a straight swap I'm around £1450 no filter or programmer and I look to make £500 off that. Funnily enough when I started going quiet I dropped to £400 and I haven't won one since.
I wouldn't fit any without a filter now, no matter how many yrs warranty it's supposed to be
You'll be hard pressed to get a free repair done in the future
If its flushed well all necessary chems put in and details recorded theyll be hard pushed not to repair.
I did one today vertical flue charged £700 labour. Gave system a good flush and tidied yp pipework
Usually get my boiler kits from Grahams, not a bad deal including filter ,flue and chems
I explain it's a good investment for the customer and it doesn't give the manus much wriggle room to welch on the warranty repair, which they will if they can
I can go to the cinema, have 5 woodbines, a bag of scrunchies on the way home and still have change from a Tanner
(and yes I did mean tanner not tenner)
Scrunchies? Aren't they hair bands? And aren't tanners people who cure leather? I'm confused.
And I thought you were Northern
Scrunchies, the bits of batter that don't stick to the fish, sausage, mars bar or whatever esle is in the cupboard
Tanner, sixpence or fortieyth of an old pound
No longer legal tender I believe
And by the way, you'll never cure leather, it's dead
I get the same from plumbs.
But I give them 2 prices with and without the mag clean.
They always go for the mag clean what i add £99 on for supply and fit.
So win win
To be frank all these i wouldnt this....I wouldnt do that posts make me raise an eyebrow.
Perhaps if i lived in windsor or harrogate id get away with that.
All my work is perfect. Neat and tidy - done the right way but market forces and region dictate largely what you can get away with charge wise.
A combi swap takes me one day and its done right and flushed.
Some either work too slow ot charge too much HAH [emoji12]
Yes I appreciate your post but one day hit man is a no from me
thats ok
If I were younger 2 a day would be possible but there were no combis when I was young
There aren't many straight swaps that take longer than a day, done properly as well.
all mine take longer than a day.
I get quite a bit of work from one day installs, replacing blocked pressure sensors, sorting vertical flues with no clips, setting the boilers up correctly so that dont continually cut out Not saying you cant do one properly in a day, but I only work 9 - 4 plus a bit of travelling, but I dont bother with lunch n breaks. So if all you morning/one day installs would like to crack on, it means I will get the repairs and servicing down the line 🙂
Thats quite a crap suggestion really even though your hiding behind a smiley face.
Your basically suggesting that my installs must be in someway inferior to yours ??.
Climb down from your ivory tower and get real. What makes you think your superior or better because you charge more and work slower ???
Are you ex council ???
So far as i can see your overpriced and slow. But bigger fool them if they are prepared to pay for your elite'ist mug to show up [emoji12] [emoji12] [emoji12] [emoji1] [emoji15]
Reply to the thread, titled "swaps (combi to combi)" which is posted in UK Plumbers Forums on Plumbers Forums.
ShaunCorbs,
quality,
