The ultimate Intergas virgin freebie boiler thread
View the thread, titled "The ultimate Intergas virgin freebie boiler thread" which is posted in Boiler Advice Forum on UK Plumbers Forums.
So let's talk about Intergas for a moment.
Is the "only four moving parts" thing meaningful to you? If so, why?
Less parts to go wrong simple as that boilers do a lot of work and anything with mechanical parts eventually break down so less means less stress surely
Hasn't the winner already been decided? It's just the losers that are being revealed very slowly
And you didn't even consider the possibility that the merchant was less than honest! Aw, bless! 🙂
Less complicated to repair with only four moving parts, also should be a lot less spare parts to carry around meaning hopefully a near first call out fix.
You two must throw great parties?? You with odd drinks and the missus with the a la carte menu haha.
It was my sons christening on Sunday. Buffet for 40. It cost me a kidney, I had to buy it all in. Caterers brought it to the house in the morning. I ate like a king!
Blimey, that pesky charge is draining again.
I had better crack on?
Anz, Hammers, Riley, CH4, are you watching?
As an outsider how many moving parts in other boilers and apart from fan & water pump what are they? (please)
Not really meaningful just marketing c@rp. 4 moving parts
Intergas:
*fan
*gasvalve
*pump
*flowswitch
Most other combi's:
Only have a diverter valve in addition to that.
My most regular repair on combis is exp vessels and prv's followed by fans on pre high efficiency boilers. Rarely gas valves, Or fans in modern boilers but then they have not been in service for 15+ years yet so I'm sure they will start going eventually.
I serviced an intergas about a week ago and I am not swayed yet. I just don't like aluminium heat exchangers.
Or swathes of plastic on boiler cases. But the lack of a diverted valve is a benefit and more so the large bore copper Heat exchanger path ways.
Simple to clean once you get the 15 or so burner door nuts off.
Lack of a diverter always a benefit pesky darn things
Reply to the thread, titled "The ultimate Intergas virgin freebie boiler thread" which is posted in Boiler Advice Forum on Plumbers Forums.
Ray Stafford,
newcastle phill,
