Those are all reasonable things to do and I don't know why they couldn't have done all that the first time round. If this was a DIY job I'd say "Well done, you've done well to get this far, just need to address a couple of issues" but for a plumber to do this, I'd be asking if he really was a plumber.
We've got the toilet not positioned where you want it, a pan connector running up hill (water flows down hill, a plumber should understand that ;-) a kinked flexi on the cold feed and and two soldered joints left in a state.
Those soldered joints need cleaning up too, the flux left all over it stands a good chance of corroding the pipe over time.
This is surely installed by a builder and not a plumber? I genuinely hate criticising other people's work and usually keep my nose out of it but these are basic things and they are not done right.
Give them a chance to put things right and only get annoyed if they can't or won't.
  • Agree
Reactions: Pickwickpick
The flux! Another problem? Should I be worried about all these too then?
It'd be worth cleaning any green staining off around the joints. It might be a bit baked on so one of those green fibrous scrubbing pads might come in useful in scrubbing that off. Just use a bit of warm water and a scrubbing pad and it'll clean up easily enough.
  • Agree
Could have been cut back! Not hard work.
As TFJ said above, first thing with any bathroom is the wc soil pipe. Dictates your toilet or the amount of work required to get a toilet to fit.
I've seen a piece of ply cut to same size as wc footprint, sanded, filled and painted white. Not done it myself though.
This works really well.
Hard to tell from the photos but the cast end looks a fair bit lower than what's been attached to it - if you got rid of that length of black plastic pipe and the rubber adaptor and see if the flexi will go straight into the cast (assuming it would fit - they sometimes do with the fins cut off).
Yep that is not right but you may as well leave it and see how it goes. The water in your toilet pan will be up higher but with the push of the water and hopefully fall on the soil pipe it should keep flushing away. Easy to sort flexi out just take it off and replace with longer one.
Reactions: Finchyboy
Good point, hadn't noticed that when I first looked at pic - the cast end does look lower. The rubber adapter is what's raising the height of flexi. I'd get rid and use a cast to plastic pipe adapter, then extend with 4" plastic pipe and appropriate pan connecter - maybe an offset one.
Is it on ground floor? My nephew had a nasty call back to a ground floor toilet install he'd done with flexi connector, poo and wee had been leaking out since he installed it (he did a top job by the way) because rats decided to run up the pipe and chew a hole in the flexi, worth remembering that one.
